Results 1 to 10 of 23
Thread: Engine light on
    Regular Member JayF's Avatar
    Apr 2011
    Bristol
    Default Engine light on
    1.9 CDTi 150 SRi 61000 miles.
    My engine light came on yesterday and now won't go out.
    It still drives perfectly and MPG is still in the 50's.
    Is there anything I can check before I book it into the garage?
    Thanks in advance.
    Regular Member wozza's Avatar
    Jul 2011
    teesside
    have you tried the pedal test to see what the fault code is? Thats is it works on your car.
    Regular Member pompey-pimp's Avatar
    Nov 2009
    Fareham Hampshire
    Vehicle : BMW 520D Touring
    Trim : M Sport Business
    Engine : 2.0 d
    Year : 2010
    It means there is a fault that has been recorded somewhere but could be something as simple as water in the fuel filter.
    Does it go out when driving?
    Buy yourself an OP-Com cable and software off Ebay then you can self diagnose. Mine was £17 and it works a treat. Local stealers want £50 just to plug in and diagnose, let alone do any work.
    Managed to find out I had a throttle actuator malfunction and now all sorted.
    My light came on last week and I sorted it by replacing the Vacuum hoses which had perished.
    Sorry to be so vague but we need more info
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by wozza View Post
    The pedal test doesn't work on the CDTi models
    If the car is not going into "limp mode", it's probably the EGR needing a clean.
    Really need to get the codes read to be sure though
    If a code scanner is not available, a good start would be to check the vacuum pipes, and remove & clean the boost sensor & EGR.
    Apr 2011
    Bristol
    The light stays on all the time. If anything it seems to go slightly better than before it came on, or I could be just imagining that. The light that is on is the engine One which I think is an emmision warning.
    The car has a pretty good warranty on it so I'll take it back to the garage and get them to check it out.
    Mar 2012
    alton
    Sounds like lamba sensor!
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by JayF View Post
    Quote Originally Posted by jock View Post
    EGR maybe?
    Mar 2012
    alton
    Could be egr but didn't think eml or emissions light came on for that.
    Apr 2011
    Bristol
    It's booked into the workshop of the dealer I bought the car from at 8.30 in the morning.
    I'll let you all know the outcome.
    Apr 2011
    Bristol
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. Engine lumpy now Engine Management Light is on
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2012, 16:51
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
