Results 1 to 10 of 17
Thread: Eml on after blanking egr
    Regular Member Allvec150's Avatar
    Mar 2012
    Salsburgh
    Trim : SRI
    Mileage : 89k
    Default Eml on after blanking egr
    Afternoon all... Well I blanked my egr valve off completely today after reading varried posts from people who have done it. Some say no light on and some say light on but after fitting the blanking plate the eml on bot right corner of dash has come on, the thing is I dont understand why because the egr is still in place and plugged in. Could it be an emissioms sensor or something? I also read that someone cleaned their turbo sensor after blanking. Anyone know where its located?
    Eml asside... there is a noticeable difference in response below 2500 rpm and it pulls better in high gears at low revs.
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Quote Originally Posted by Allvec150 View Post
    I think the ecu uses both maf sensor and map sensor to detect a pressure difference when egr opens when you blank it theres no pressure diff so it puts the eml light on, ive blanked mine the light is nowt to worry about, as for the turbo sensor i think what your describing is the map sensor(manifold absolute pressure) it located on the back of the inlet manifold to the left of the egr its got an electric plug and 1 star drive screw holdin it in,its about the size of a matchbox
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Needs to be mapped out if ya blanking it off mate
    Mar 2012
    Salsburgh
    Trim : SRI
    Mileage : 89k
    Default Thanks guys.
    Thanks for your input guys, I should have said its a 56 plate cdti150 but anyway I will have a look for the sensor and give it a clean and when you say it has to be maped out do u mean that an ecu remap is the only way to put the light off? At present Ive got a plug n play chip fitted and a re map is expensive.
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by paulvectrac View Post
    Unless you drill a 6mm hole in the centre of the blanking plate!
    Nov 2009
    Argyll
    Can you blank off the egr if you have a DPF fitted? I've read that you shouldn't but theres loads of folk on this forum with the same car and engine as mine who have. Just so you know I've got a 1.9 CDTI 150hp. EML came on a couple of weeks ago, my local garage (not vx) said it was the EGR valve. I took it off, cleaned it, replaced it, then two days later the EML light was back on!!!!!
    DONCASTER
    I have a DPF on mine. I've just replaced the inlet manifold, timing belt and water pump. Cleaned the EGR, turbo boost sensor, throttle body and blanked the EGR. The difference is amazing, much smooth, pulls harder from lower down right through the rev range. eml warning is lit but covered which I can live with. Personally I can't see the point in drilling a hole in the blanking plate nomatter how small. It simply defeats the object of fitting a blanking plate which is to stop all the crap going through the EGR into the engine and causing problems.
    Engine : 1.9 CDTi
    Drilling the hole helps increases the speed the fumes go through so they dont cool as much or have time in the egr to clog it up again.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Map it out drilling a hole is pointless if I'm honest, been there & done that to absolute no avail. If you don't want to map it out, just remove the plate and run as normal. As long as there is gases passing from the exhaust manifold to the inlet manifold you will always get clogging up of the valve and manifold.
    Regular Member coooky's Avatar
    May 2011
    washington
    blanked mine off and no light on and no 6mm hole
  1. EGR blanking
    By MattDC in forum Diesel Engine related
    Last Post: 15th March 2012, 10:19
  2. EGR Blanking
    By dc6839 in forum Engine & Drivetrain
    Last Post: 18th July 2011, 21:10
  3. Blanking egr
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2011, 18:21
  4. blanking egr
    By nickdti in forum Engine & Drivetrain
    Last Post: 11th June 2011, 07:58
  5. EGR blanking
    By ctj in forum Engine & Drivetrain
    Last Post: 1st January 2011, 02:17
vectra eml reset
vectra c egr plate causing eml
saab vectra egr blanking
egr blanked off eml light reset vectra 1.9cdti
egr blank with no eml light
