Thread: Slight whining noise
    Feb 2012
    Scotland
    Default Slight whining noise
    Hi Guys,
    I noticed today that when i accelerate, even gently there is a very slight whining noise and if i accelerate hard there is a sucking noise for a split second
    What could be causing this ?
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Well, assuming that it's not the wife and/or kids whining (to which the answer is to turn the radio up louder) we need to know which engine you have.
    Feb 2012
    Scotland
    I have the z18xer engine,
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    Same engine as me, and it's not a noise that I have heard.
    The 1st thing I would check is the air intake, airbox, MAF sensor and air feed to the engine. All these bits are plastic and subject to spliting and coming off if the clips are loose.
    Another thing is how old is the battery?
    Feb 2012
    Scotland
    The Battery has been on the car since new (2008)
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    The ? about the battery is in case it's not holding its charge.
    The noise could be, say the heater fan, spinning up because the rev's have gone higher and the voltage has risen and now you hear the fan.
    Just a thought, I have already replaced the battery in my 2008 model with a much bigger capacity one. I had a couple of starting problems before that.
    Feb 2012
    Scotland
    Just been out and took it for a run, the engine seems a bit louder than normal and there is a definate whine. While haveing a look under the bonnet i noticed a wire that runs along the side of my airbox has been rubbing onto the auxiliary belt and had burned through the plastic and now to the bare wire, do you by any chance know what this wire is for ?
  1. whining noise
    By Swedge in forum Engine & Drivetrain
    Last Post: 21st November 2012, 23:23
  2. Slight whining from the engine area...
    By swirl80 in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2009, 21:34
  3. whining noise (HELP)!!!!
    By wilsons 1.8sxi in forum Engine & Drivetrain
    Last Post: 20th March 2009, 09:03
  4. Whining Noise
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 11th August 2008, 09:08
  5. Whining Noise
    By v6boy in forum Engine & Drivetrain
    Last Post: 13th May 2007, 01:13
