Results 1 to 3 of 3
Thread: HELP Play in new cambelt tensioner 1.9 cdti
    Regular Member Diesel Dude's Avatar
    Norfolk
    Default HELP Play in new cambelt tensioner 1.9 cdti
    Now changing the cambelt on my 1.9 cdti 150 fitted the new pulleys in the kit fitted the new tensioner refitted the cambelt timed it all up ok but i have noticed play in the new tensioner. If i push and pull on the new tensioner pulley towards and away from the engine block there is about 1-1.5mm of movement with everything tight is this normal all genuine Vauxhall bits. anyone noticed this or is my new tensioner faulty.
    Glasgow
    Have you adjusted the tensioner or just bolted it on? You have to adjust it to take it up the slack and make the belt tight.
    Norfolk
    Yes ive adjusted the tensioner everything is ready to go but the movement is towards and away from the block asif the bolt isn't tight but it is tight
  1. CDTI 150 Aux Belt Tensioner Part No?
    By Leemarksmith in forum Engine & Drivetrain
    Last Post: 25th January 2013, 22:15
  2. Cambelt and tensioner kit changed but not waterpump
    By Meerkatonacid in forum Engine & Drivetrain
    Last Post: 13th June 2012, 19:33
  3. cambelt tensioner postion correct???
    By Mads in forum Engine & Drivetrain
    Last Post: 9th March 2011, 01:00
  4. Setting cambelt tensioner 1.9cdti 150
    By Vectra Meldrew in forum Engine & Drivetrain
    Last Post: 28th August 2010, 13:31
