Thread: Parott kit
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Default Parott kit
    i just brought a Parott kit a MKi 9200 off the bay brought this particular one as it was fitted in a face lift veccy so should fit straight in to my vec with the correct wiring kit which it came with.
    I had this kit in my turbo Xp and it was brill. question is in my turbo when the parott kit was being used it showed EXTERNAL in the display and it muted the head unit.
    now after installing this kit it dosnt do this but does mute the head unit except for the little speaker on the dashboard which means i have to turn down the volume on the head unit?.
    It also dosnt show external on the head unit display when its being used?
    question is how do i solve this? and also is there a lead i can buy to use the parott kit with my steering wheel controls
    thanks guys
    Are you VXR Enough
    13 Post(s)
    bump
    Regular Member wildchild's Avatar
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Engine : 1.9 cdti 16v 150
    Year : 06
    Mileage : 111250
    hi m8 i think you have to connect the pink and yellow wires together to work the mute hth
    gaz
    Are you VXR Enough
    13 Post(s)
    pink and yellow wires fella?
    Are you VXR Enough
    13 Post(s)
    bump
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Not sure on full can mate there is a lead u can buy for the controls but it's dear iirc have u got a pic of the wires I would have a look at mine but carnt get the hu out
  1. Parott MKI9100 replacment for IO Play
    By karldower in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2009, 16:47
  2. Fitting Parott CK3100 in a Signum 56 Plate ????
    By ian001 in forum Electrical & ICE (including SatNav)
    Last Post: 28th July 2007, 21:49
