Thread: 2.2 direct.poor running.fault codes.p1191 & p1112.please help.
    Jun 2009
    Middlesex
    Default 2.2 direct.poor running.fault codes.p1191 & p1112.please help.
    Took car out and engine management light came on (car & spanner warning light on dashboard).Mechnic read fault codes on Snap-On diagnostic equipment and fault codes read-
    P1191 fuel rail pressure sensor circuit
    Possible causes -wiring fuel presure regulator
    electronic control module
    P1112 Deactivation solenoid valve circuit
    possible causes-wiring,intake manifold flap
    hose connection(s)
    intake manifold control actuator
    I have already had Fuel pressure Regulator & H.P Fuel Pump replaced at Vauxhall 3 years ago at a lot of personnel expense.
    Can anyone help with what to do next?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Well upgaded parts for FPR and HP Pump came put agter that so properly one of thise have failed again. Irs just witch one.
    You need to know the sub-code for 1192 to tell witch is Wong
    Engine : 2.2 Direct
    Jun 2009
    Middlesex
    Thanks for trying to help.I don't know to much about the mechnics of the Vectra but do you mean Sub Code for p1191 or P1112 and not 1192.
    What is the Sub Code and do i need to take it to VX for this.
    Thanks.
    Engine : 2.2 Direct
    Because its different what the error is depending on sub-code see my old thread here:
    http://www.vectra-c.com/forum/showthread.php?t=133868
    Jun 2009
    Middlesex
    Thanks Kenp,but having real problems on understanding any of this and not knowing what to do next.Can't beleive my replacement H.P Fuel Pump and Regulator lasted less than 3 years .Where do i start?
    P.S Read your thread.
    Engine : 2.2 Direct
    You start with checking as the procedure says.. (also in the link) else you only have the option with replace until fault is cured.
  1. 2.2 direct petrol 05. Fault codes
    By mani2002uk in forum Engine & Drivetrain
    Last Post: 2nd May 2012, 15:35
  2. 2.2 direct serious judder/poor running!help!
    By leem82 in forum Vectra C / Signum Car Chat
    Last Post: 9th October 2010, 10:59
  3. Replies: 13
    Last Post: 20th May 2010, 20:09
  4. 2.2 Direct (Z22YH) - P1191 Error
    By johnmac in forum Engine & Drivetrain
    Last Post: 2nd April 2010, 00:40
  5. Sick Signum 2.2 Direct (Fault Codes)
    By kaston in forum Engine & Drivetrain
    Last Post: 13th September 2007, 10:31
vauxhall p1191
vauxhall 2.2 direct petrol p1112
p1112 vauxhall
zafira p1191
vauxhall vectra 2.2 direct fault code p1191
vectra c 2.2 direct actuator
P1191-5a
vauxhall vectra 2.2 direct faul codes
error code p1191
z22yh p1191
engine code p1191
p1191 zafira
opel zafira P1191-5A
vauxhall vectra 2.2 petrol poor running
opel zafira p1191
p1112 vauxhall zafira port deactivation solenoid
p1112 port deactivation solenoid
https:www.vectra-c.comforumshowthread.php159852-2-2-direct-poor-running-fault-codes-p1191-amp-p1112-please-help
p1191 vectra 2.2
p1112 vauxhall vectra 2.2 petrol
vauxhall vectra 2.2 p1112
vauxhall vectra c p1112
vectra c 2.2 direct poor start
opel zafira p1112
Error code P1112 signum
