Thread: loosing engine coolant
    May 2011
    sunderland
    Angry loosing engine coolant
    The engine coolant light comes on then when i take off the expansion cap the water level goes back to normal any ideas car is vectra c 1.9 cdti 06 plate
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Are you having to top system up?
    May 2011
    sunderland
    Yes but sometimes there is more water in than in before if that makes sense its as tho it usnt moving around the engine
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Sounds like there is an airlock somewhere. There's also a chance the coolant tank cap is faulty after reading your other thread, as it may not be allowing the tank to vent the excess pressure build up
    May 2011
    sunderland
    So do you not think its the head gasket seems like the water isnt movin round the engine but when i release the cap the level goes back to normal hope it aint the hg
    May 2011
    sunderland
    Morning lads,gotta vectra cdti 1.9 06 plate recently been using about half a pint of water a week cant find any leaks ive had it pressure tested and the lad says im losing pressure but only very slowly. He also done a sniff test went from red to a slight yellow he said its the head gasket but he doesnt trust the sniff test coz they are unreliable. If it is the head is there any stuff on the market which i can pour into the header tank to reseal the head gasket . Ive seen a few products but do they work?? And also the temp guage has got a mind of its own goes up and down then stays on 0 then up and down again the water pump was done last month also cheers
  1. 2.8 Veccy loosing coolant!
    By the_rocker in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2012, 14:17
  2. Loosing Coolant
    By Coupe2T in forum Engine & Drivetrain
    Last Post: 2nd April 2012, 10:03
  3. loosing engine coolant
    By pud wayman in forum Engine & Drivetrain
    Last Post: 13th March 2012, 09:14
  4. Loosing coolant & foaming
    By si_hoss in forum Engine & Drivetrain
    Last Post: 27th January 2012, 14:12
  5. loosing coolant oh oh
    By toast in forum Engine & Drivetrain
    Last Post: 21st June 2010, 22:03
vectra c yelow coolant
