Results 1 to 10 of 28
Thread: coolant going somewhere
    May 2011
    sunderland
    Angry coolant going somewhere
    Im loosing water in the header tank ive got a vectra cdti 1.9 the coolant light comes on then after i carefully open the header tank cap the water comes back????? Any ideas
    Glasgow
    Don't take the top of the header without letting the car cool down first. How is the level when the engine is cold?
    May 2011
    sunderland
    Hi mate the level is normal,heaters ok,temp ok,performance ok just when the coolant light comes on there is not much water in the expansion bottle but when the pressure us realeased the water comes back ....hope it isnt a hg gone hopefully its the expansion tank or cap ....thanks for the reply
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Could be air lock in the system.
    Are you having to top up the system when cold? If so I'd be saying headgasket
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    May 2011
    sunderland
    Normally when driving around when engine is warmed up level normal when cold but when the light comes on i carefully release the expansion cap the water level comes back
    Glasgow
    The level drops when the engine is upto temperature, the cap is'nt supposed be opened when the car is warm 1: a rapid de-pressure of the coolant system can cause damage and 2: your putting yourself at risk of needings skin grafts if it scalds you.
    If the level is fine when the engine is cold dont worry, it will drop when its warm as long as it rises again as the car cools down.
    My first port of call would be the coolant level sensor and put a new one in as it sounds faulty.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    If its not using any coolant, try pumping bottom hose as it heats up to make sure no air in system
    May 2011
    sunderland
    Should i replace the expansion tank and cap.aswel i thought it might have been the hg but no mayo in the oil filler cap but hopefully not
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    No leave it off whilst you do it. If still no joy.
    I'd be prepared to put money on its headgasket
  1. Coolant
    By tubby in forum Engine & Drivetrain
    Last Post: 16th November 2012, 21:36
  2. which coolant ??
    By VecPower in forum Engine & Drivetrain
    Last Post: 30th October 2010, 18:04
  3. Coolant Top Up
    By alembicbassman in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2010, 15:54
  4. Coolant
    By Bloicy 3.2 V6 GSI in forum Engine & Drivetrain
    Last Post: 23rd August 2009, 12:19
  5. Oil in Coolant!!!!!!!!!!!
    By mipai in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2009, 14:43
