Results 1 to 10 of 14
Thread: need help quickly please people!
    Aug 2011
    north wales, criccieth
    Default need help quickly please people!
    car has been struggling to start last few days but i put it down to it being damp and cold... however today i drove to the chippy not a problem, but after i got my food i came out and nothing happened when i turned to key. lights came on for ignition but car would not start, not even turning over or even trying to. i bump started the car and it went no problem and now iv got it home and turned it off there is nothing again... is my starter motor gone or is it something to do with coil or glowplugs. iv recently replaced the thermostat so could i have done something wrong there?
    thanks for any help guys but i need to get this sorted asap as its needed for work..
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    How old is the car?
    Could be your alternator or more likely your battery if you managed to bump it, I've just replaced my battery on my '04
    Regular Member lutonmatt's Avatar
    Feb 2012
    kent
    i would say battery as well
    Aug 2011
    its and 04 1.9cdti guys. 150 spec.
    Aug 2011
    and i didnt think it was the battery as everything else was working fine, there was no drained signs or struggling to start or anything prior to it not starting.
    Regular Member Beebs's Avatar
    Livingston
    Could be the solenoid on the starter. If this does not energise then the starter does not get the power to engage.
    Regular Member gsi-robster's Avatar
    Mar 2012
    paisley
    starter solenoid wire been pulled off ?
    starter knackered ? or cabling ?
    start relay?
    Aug 2011
    where is the starter located on my engine then. could i have knocked a wire when doing the thermostat or something?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    get your battery tested bud cos its most likely that
    falkirk
    Sounds similar to an issue I had-new battery will sort problem
  1. How quickly should the eml go out?
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2012, 10:58
  2. Replacing V5C quickly
    By Keif in forum The 'Off Topic' room
    Last Post: 26th June 2011, 12:41
  3. help quickly, running out of light
    Last Post: 2nd April 2011, 16:44
  4. I'm impressed -Then quickly depressed
    By paulf in forum Detailing and Car Care Discussion
    Last Post: 1st July 2009, 13:10
  5. Anyone know how to wind up a ltd company quickly
    By martind511 in forum General Chat
    Last Post: 5th July 2007, 21:21
