Thread: front wheel bearings!
    Regular Member jimbo1987's Avatar
    Jan 2012
    southwest
    Default front wheel bearings!
    does anybody know how i can find out if my 2002 1.8ls has ids, ive gota change my front o/s wheel bearing and have just found out that it comes in the hub and there is two types 1 with ids and 1 without.
    cheers.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    If you have sport button yeah if not no
    Jan 2012
    southwest
    thats a no then!!! wish i had a sport button. cheers are they easy to fit have only ever done rear 1s on a older car that didnt come in hub???
    easy as pie mate
    remove caliper
    remove caliper carrier and disk
    remove track rod end
    lower wishbone from hub
    disconnect abs plug
    unbolt hub from bottom of shock
    take hub to bench
    undo 3 bolts on inside of hub
    knock out old bearing
    insert new bearing making sure abs cable is on the same side as old one
    refit new bolts and torque up
    put back together
  1. Best place to buy front wheel bearings?
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 10:08
  2. Front Wheel Bearings
    By Padster72 in forum Suspension, Wheels & Brakes
    Last Post: 10th May 2009, 20:00
  3. GSi front wheel bearings
    By gtr1000 in forum Suspension, Wheels & Brakes
    Last Post: 23rd November 2008, 17:38
  4. Think my front wheel bearings have gone
    By vectravirg in forum Suspension, Wheels & Brakes
    Last Post: 26th June 2008, 19:12
  5. How to replace front wheel bearings
    By Aleco in forum Suspension, Wheels & Brakes
    Last Post: 31st March 2007, 21:16
how to fit front bearing hub vectra c 1.8 ls
