Thread: Blowing exhaust and slight oil leak?
    Regular Member Tinks's Avatar
    Jan 2012
    Whittlesey
    Vehicle : Vectra C Elegance
    Engine : 1800
    Mileage : Lots
    Default Blowing exhaust and slight oil leak?
    Good day to one and all!!
    1.8 16V 2003 with blowing flexi pipe. Is it only the specific exhaust that will fit or would something like the SRi manifold back system fit?
    Asking about the SRi system as an example as I want to change the back box and the SR looks nice for an OE tail pipe - thinking 2 birds 1 stone.
    As for the oil leak - I think this may be coming from the oil level sensor thingy on the front of the sump. Anybody know if this is a common thing??
    Help always greatly received.
    Tony
    Regular Member Das's Avatar
    Here
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    1.8 has a Manicat set up so you'll just have to either replace the front pipe or find an exhaust place that can weld in another flexi. Carpartsconexxions showing a front pipe at £41 inc VAT, for a part thats £120 from the dealers, maybe another £10 for delivery. SRi will be exactly the same front pipe, the 1.8 SRi is exactly the same as the 1.8 LS, its just got a closer ratio gear box to make it slightly quicker.
    http://www.carpartsconnexion.com/vau...=24447469&p=1&
    As for the oil leak, not sure. Degrease and check its defiantly that. Might be just a case of removing, cleaning and use some instant gasket to reseal.
    Here
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Jan 2012
    Whittlesey
    Engine : 1800
    Mileage : Lots
    Cheers Das, could I not just remove the flexi / minicat and weld in a solid section?
    Thanks for the supplier info - if all else fails ..........
    Cleaned it up this afternoon so will see how its fairs tomorrow.
    Thanks again mate.
    Jan 2012
    Whittlesey
    Engine : 1800
    Mileage : Lots
    Thanks again mate.
    Here
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Wouldnt think so, but a few have had new felxi's welded quite cheaply.
  1. 2.2 slight oil leak still.......
    By Lordish in forum Engine & Drivetrain
    Last Post: 3rd April 2012, 07:29
  2. Slight Radiator Leak
    By stevie16v in forum General Chat
    Last Post: 19th February 2012, 15:47
  3. slight oil leak
    By srikev in forum Engine & Drivetrain
    Last Post: 18th August 2011, 23:23
  4. slight oil leak
    By BRIANE in forum Engine & Drivetrain
    Last Post: 26th July 2008, 18:17
  5. Slight oil leak, 1.9CDTi.
    By pricey in forum Engine & Drivetrain
    Last Post: 22nd May 2008, 19:28
