Thread: Relay or fuse
    Regular Member VECTRAMAN's Avatar
    Bridgend/South Wales
    Vehicle : 1.9 CDTI Design Estate
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    Default Relay or fuse
    Is there a relay or fuse that controls the O2 sensor
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    No fella there isn't what's the problem with it
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    Just fault code all the time P0170 fuel trim bank 1 - no air leaks,new air filter,plugs,cleaned throttle body(was stinking).No egr fitted as Z18XE engine on 2006
    Can maf be cleaned and what with,trying low cost route 1st. Might be o2 sensor,Maf sensor or coil pack as I have been led to believe.
    Regular Member lutonmatt's Avatar
    Feb 2012
    kent
    will be the o2 sensor
    Are you VXR Enough
    13 Post(s)
    yep Matt is right it will be the 02 sensor bud
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    Cheers guys,was next on list as cheapest 1st..
  1. small fuse/relay box?
    By neill in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2011, 18:20
  2. rear wiper fuse/relay
    By johnrolfe in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2010, 18:39
  3. Engine Bay Fuse/Relay Box Query....
    By Tony W in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2010, 12:58
  4. Engine Bay Fuse/Relay Box Query....
    Last Post: 14th April 2010, 18:23
  5. f1 Fuse - possible relay problem!!!
    By az sri in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2008, 02:03
throttle body fuse vectra c
throttle body fuses vectra c
