Results 1 to 10 of 15
Thread: Cam Sensor replacement
    Regular Member Barlow's Avatar
    Jan 2012
    Chester
    Vehicle : Nissan 350Z GT
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Default Cam Sensor replacement
    I removed the Timing belt cowling to start replaceing my Cam sensor when I noticed it sits behind the cam vernier wheel. I replaced the cowling and went inside to sulk.
    Last time I touched a timing belt I destroyed an engine.
    I got a quote from a local garage that said it would take 45 minutes and would cost £30-£40 (me supplying the sensor)
    That sounds a little quick to me, as if he doesn't realise the sensor is behind the V-wheel. What do you guys think?
    1.9 120
    Jun 2012
    scotland
    Vehicle : astra
    Trim : sxi
    Engine : 1.9
    Default camshaft sensor
    hi barlow, iv just had the same quote for changing sensor on my 1.9 120 £30.00 i provide the sensor. just wanted to ask why you are changing yours, i took my car in as its a pain to start from cold so had it on diagnostics thinking the glow plugs will be the problem but cam sensor fault showing, did you or anyone have the same problem as me
    Jan 2012
    Chester
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    lol, you've got exactly the same problem as me. Error code showing cam sensor, poor cold starting.
    It's probably not the cam sensor to be honest, after a couple of weeks that error cleared, but I still have cold start issues. It's almost certainly the starter motor (See other thread in the tech problem forum), I just havent had the time or money to change it yet.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    have a look at this lads i believe its your starter motors
    http://www.vectra-c.com/forum/showth...=starter+motor
    right post now
    Jan 2012
    Chester
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Yeah, as Ste said Starter motor. Sorry JayKay, I was in a rush when I typed that message.
    It will almost certainly not be your glow plugs, EGR, air filter, fuel filter, leak off pipes, Battery, DMF, or any number of other suggestions you'll hear. I've done them all.
    The only possible thing it can be is cam sensor (which I now know it isn't) or Starter. The Starter sounds fine, but it really isn't.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    The Starter sounds fine, but it really isn't. your correct
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    have a read of this as well
    including a video
    http://www.vectra-c.com/forum/showth...t+motor+sounds
    Jan 2012
    Chester
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Yep, mines starts if you keep priming it. I was going to put a none return valve in. Glad I didn't.
    Weird problem with weird symptoms
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    hope you get it sorted this time
    Jun 2012
    scotland
    Vehicle : astra
    Trim : sxi
    Engine : 1.9
    hey thanks for the advice guys, will try get another vectra next to mine and see if they sound the same, will keep you posted.
  1. Replies: 3
    Last Post: 13th August 2012, 22:25
  2. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  3. Egr sensor replacement
    By billy_wiz in forum Y & Z30DT Specific
    Last Post: 29th January 2012, 12:16
  4. Rain sensor gel replacement
    By Aidi in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2011, 18:45
  5. Brake Pad Sensor Replacement
    By andy13 in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2008, 20:31
were is the cam sensor vectra c 1800
