Results 1 to 10 of 20
Thread: What's the easiest way to drain the coolant on the GSi ?
    Regular Member muffking's Avatar
    Default What's the easiest way to drain the coolant on the GSi ?
    Another quickie guys.
    What's the easiest way to drain the coolant on the GSi as I've got mucky water (as they say)
    [Ex]Admin Duncan's Avatar
    I know a man who'll definitely be able to answer that one - Mark (GSi3.2) but he may not be around until later.
    Hopefully somebody can answer in the meantime.
    Mileage : 000
    When you say mucky water, how do you mean, is it contaminated with oil, if so it may mean some problems,
    Nicking Ya Dinner.
    Sounds more like mixed colours of anti freeze, goes rusty brown and looks ugh!, wouldn't swear to it, but probably undo rad hose and stick a hose in the filler bottle to flush system with fresh water, then pre mix anti freeze in a watering can and re-fill.
    I'll do that then unless there's a drain plug somewhere.
    The water is brown in colour, but there could be a hint of something oil based as it seems to have some splodges in the top of the header tank.
    Nicking Ya Dinner.
    Best hope someone hasn't red welded it, that can also give that effect, it probably is mixed anti freeze though, wait until Mark surfs in, he'll know the whole issue.
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    took the hose off on mine much quicker
    Regular Member hagga's Avatar
    kingswinford
    Quote Originally Posted by muffking View Post
    hammer a screwdriver into ya rad.. sorry..lol...been a tough day
    member of the smoke patrol 230bhp+
    taking the bottom rad hose is the way to go
    its very messing but works
    if your going to do it this way dont get under the car to pull the hose off
    remember to get antifreeze for the car befor doing it
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    There's a drain plug under the waterpump housing on the 2.2 so you can drain the engine block but not sure on the other engines....
  1. drain coolant without taking bumper off
    By andy_richmond in forum Vectra C / Signum Troubleshooting
    Last Post: 14th December 2012, 09:43
  2. 1.9CDTI (120) - Coolant drain point
    By snapsnap in forum Engine & Drivetrain
    Last Post: 27th May 2012, 11:56
  3. easiest way throug bulkhead?
    By opel_estate in forum Electrical & ICE (including SatNav)
    Last Post: 22nd April 2011, 10:41
  4. Drain Plug - Coolant
    Last Post: 22nd June 2009, 13:53
  5. Anyone tell me how 2 drain the coolant?????
    By frazejax in forum Engine & Drivetrain
    Last Post: 25th August 2008, 09:04
coolant on vectra gsi
vectra c radiator drain plug site:www.vectra-c.com
