Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: 2.2 Direct Misfire Problems :(
    Mar 2012
    kent
    Angry 2.2 Direct Misfire Problems :(
    Hi, I am looking for some advice for my Vectra.
    Basically I was travelling home from work Tues mainly sitting in traffic and when pulling away the car started to judder. The yellow spanner light illiminated so I pulled over and turned off the ignition. I then restarted the car which turned out the light but now the car keeps misfiring under load.
    After reading through the forums I purchased some new plugs & coil pack which i fitted today but the car still does the same?
    It idle's fine and drives ok at very low revs, but as soon as you accelerate above 3/4k it starts to misfire, ending up losing virtually all power.
    The EML came on so I have plugged my code reader in and im receiving error p0303.
    I dont know what next to try, so would appreciate any help.
    John
    Regular Member Kcriyback's Avatar
    Jul 2011
    Edinbourgh
    I had the same problems.
    I changed the plugs.
    Took off the egr and cleaned it.
    Also the fuel preasure pump got striped n cleaned out with oil change
    And its running like new now.
    Dont know if it will help
    I am here: http://tapatalk.com/map.php?asg3b3
    Full Member spennny's Avatar
    Blantyre
    Same symptoms as mine when the high pressure fuel pump went mate , have you had the regulator changed and what make is the HPFP on the engine, siemens or continental
    Just to add mine through up a fuel reg fault when it was infact the pump
    Sent from my iPhone 4s using Forum Runner
    Mar 2012
    kent
    Thanks for the help, where is the egr valve located?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Its not the EGR mate its the HP pump on the Fuel rail, odds on its a Siemans and this will be the cause of your problem, its a very easy job to swop it over. The EGR by the way is on the side of the engine next to the battery box, its water cooled so if you unbolt it you will have to drain and refill the coolant system.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    It could be either FPR or HP pump (or both). in the last year ive changed both.. as i same problems like you.
    Only way to determin what fails is to have faultcodes read out, but sure sounds like the HP pump (takes 20 minuts to change.... and not even that long)
    Mar 2012
    kent
    Many thanks to all for the replies. I have just taken off the pump and cleaned out using some degreasing spray down the nossels. I did not have the correct torx socket to undo but even with this small clean, I have just driven 5 miles without no misfiring except if i let the revs past 3k. Does this sound like the pump for definate as I have just shed out 180 pound on coilpack and plugs and am looking at another 300+ for the pump.
    Regular Member davidlewis24's Avatar
    bridgend / wales
    Quote Originally Posted by jonny180 View Post
    what is the make of the pump mate ?
    Mar 2012
    kent
    Siemens unfortunately
    Engine : 2.2 Direct
    That sounds like the pump.. (i drove home 375 miles with a defect HP pump)
    Seach the bay for cheaper Continental replacement..
  1. 2.2 direct misfire
    By lh_4827 in forum Engine & Drivetrain
    Last Post: 22nd November 2013, 19:55
  2. 2.2 Direct 54 misfire sometimes
    By rodzynx in forum Engine & Drivetrain
    Last Post: 4th March 2012, 12:22
  3. 2.2 direct misfire/lack of power problems.
    By fidzer in forum Engine & Drivetrain
    Last Post: 28th February 2011, 01:33
  4. Z22YH (2.2 Direct) Misfire
    By johnmac in forum Engine & Drivetrain
    Last Post: 16th July 2009, 22:31
  5. 2.2 Direct misfire codes- help please!
    By mostynmiller in forum Engine & Drivetrain
    Last Post: 27th February 2009, 20:31
