Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: ANy clues to help me on this issue???
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default ANy clues to help me on this issue???
    I have had an accident involving a cat running out to road where I could not avoid but it broke water and air radiator, so went to DIY replaced both. Worked fine but turbo started to whine loudly after testing... Then 10 minutes later turbo broke. Ok, got new turbo unit fitted by me, carefully replaced everything correctly, also egr valve replaced...
    Refitted everything back, checked every hose to see its all ok without any split, no evidences of any damage/split,
    Everything back on, new oil in as well....
    Cleared all codes before running car as it was showing 50 codes!!! Only 2 came on, both related to lighting issue but checked and configured, no fault codes now....
    Took car for a drive but still smoky, it drives like no turbo but turbo runs fine but won't kick in, no lights comes up now spanner car thing goes out 5 seconds before I start car so know car is ok.
    I'm confused! We got a holiday next week! Blasted cat!!!! Help or ideas please.... Really desperate now to solve this issue???
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Have you checked for split intercooler and intercooler pipes?
    is there any smoke coming out of the engine bay when you rev the car?
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    Still smoke and no turbo, sounds like the boost pipe us split/leaking or egr stuck open. How bad is the smoking?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Smokes out of the exhaust when I idle rev and when driving it smokes a lot, greyish smoke, not black like 2 days ago when turbo broke.
    I did check all hoses for split etc, all seems good,
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Nov 2011
    Cheshire
    Engine : 1.9DT
    Mileage : 100k
    Do you hear the turbo whistle?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Being hard of hearing is an issue! Lol
    Will tow car to dad in law who got a lifting ramp to do it there and then to find out properly.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Nov 2011
    Cheshire
    Engine : 1.9DT
    Mileage : 100k
    It's possible the smoke is a bit of a red herring, did you have the vac pipes off is it poss the actuater on the slam panel got disturbed, basically check all vac pipes are in the right place, it could also be the boost sensor, take it out and give it a clean.
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Sounds stupid i know but you didnt over fill the oil? Or when turbo broke it could have pushed a load of oil through boost pipes into inlet manifold mabe?
  1. Hid a serious issue ?
    By Elahi_786 in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2010, 02:28
  2. Key fob issue
    By mo1710 in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2010, 01:25
  3. key fob issue
    By doghead632 in forum Bodywork & Interior
    Last Post: 25th August 2009, 10:22
  4. The Clues are there
    By Dodger in forum Comedy & Humour
    Last Post: 6th November 2007, 18:48
