Thread: Is this split
    Jul 2011
    UK
    Year : 06
    Default Is this split
    And needing replaced the hose on vacum thing got small slice but can see clear pipe inside
    Went inside came back out out found this
    Sent from my HTC Desire HD A9191 using Tapatalk
    Full Member spennny's Avatar
    Blantyre
    Dunno about the pipes but Yer CAT looks knackered lol
    Jul 2011
    UK
    Year : 06
    Haha yer it does lol
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    Looks like a big slice, if it were leaking from there its likely the turbo wouldn't work at all. A bit of electrical tape wound tightly would make a temporary repair but id get them all replaced.
    Jul 2011
    UK
    Year : 06
    How many is there to replace was going get some blue 4mm
    Nov 2011
    Cheshire
    Engine : 1.9DT
    Mileage : 100k
    I just did mine although I have a 120 so may be a little different, I ordered 3M of 4mm and it was just enough. If you follow the pipe from the vac pump all the way to the turbo and replace all if the rubber parts.
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Its not a slice but a joint.if you pull it apart ull fine a little plastic joining bit inside.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Quote Originally Posted by justin32 View Post
    If it is slack put jubilee clips on it, but I dont think that is your problem unless you have seperated it recently.
    3.2 v6 Signum and loving it
  1. Split pipe
    By LeeU in forum Diesel Engine related
    Last Post: 10th September 2011, 20:38
  2. split pipe
    By pacman696 in forum Engine & Drivetrain
    Last Post: 6th June 2011, 21:04
  3. split intercooler!!!!
    By wrayballs10 in forum Diesel Engine related
    Last Post: 12th January 2011, 08:40
  4. Split Second
    By B00mer in forum Games Room
    Last Post: 24th April 2009, 16:14
  5. Really off topic - Ever get a split lip
    By Leviathan in forum The 'Off Topic' room
    Last Post: 20th June 2008, 09:11
