Results 1 to 10 of 13
Thread: Help Needed Please...Knock knock...
    New Member wishy1976's Avatar
    Nov 2010
    telford
    Unhappy Help Needed Please...Knock knock...
    hi there ,I need help,well thats what the misses says any way,
    vectra c 2.2 sri 2002 owned for 5 years
    I've had the dreaded knockin at rear of my vectra C 2.2 sri for about 6 months
    read all how 2's on this site,which was more helpful than Haynes Manual
    and have replaced both upper control arms yesterday,
    and replaced rear anti rool bar bushes today
    the ride feels so much better and both rose bushes WERE knacked on hub side
    a lot of knockin as now gone but i still get knock from o/s/r
    check usual exhaust/boot catch
    would a shock knock if knackerd??
    it def sounds like knockin comin from o/s/r suspension at below 30mph
    above that noise seems to vanish
    any suggestions?
    would be appreciated.
    Thank you Dave
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Yes a shock could make a noise if the gas/oil has escaped. Also worth checking the rear drop links as well
    East Ayrshire
    Trim : SRI XP1
    What about the rear anti roll bar drop links?
    Nov 2010
    telford
    Question knock at rear still
    Hi ,super quick response that matey
    its doin my nut in now.
    thought ctl arms and anti roll bar bushes would have cured it but no such look.
    shock dosnt seem to have leaked,
    but wether you can tell or not,
    if i do remove shock would i be able to tell ?
    or if drop links would i feel any movement??
    Northampton
    Engine : A20DTH
    Mileage : 88000
    If you took the shock off you should be able to tell. I have done quite a few shock changes now and you will find that if they are faulty they push in really easy or do not push in smoothly.
    have you checked the springs to see if you have broken one, its a common issue?
    East Ayrshire
    Trim : SRI XP1
    There would probably be a little bit of play in the rubber mountings. Not an overly expensive part http://www.ebay.co.uk/itm/VAUXHALL-V...item2ebb8a0dc7
    Good idea for checking the springs aswell, you'd probably have noticed that when you where changing the control arms tho
    Nov 2010
    telford
    yes folks removed springs to get better access to the dreaded inner torx socket for control arms.
    will check out link from stevie16v in a minute
    will remove shock tomorrow when the sun comes up....
    to see if anything wrong with that
    if thats seems fine i will blow my top......
    Nov 2010
    telford
    nice link stevie .
    for the price of £20 plus free postage for a pair of drop links
    I will order those aswell now ,and put them on as soon as they arrive,
    (are they as straight forward as they seem to take off..?)
    if shock has gone aswell any one suggest a link or site for direct replacement shock at reasonable price?
    thanks for great replies folks
    Nov 2010
    telford
    great link stevie , will purchase drop links now for that price,at least its 1 more thing that he cant be when replaced..
    any thing hard in replacing d/links
    if shock as gone when i remove any body got link to cheap shocks that are as good as oem shocks.
    I take it they will have to be swapped in pairs....?
    East Ayrshire
    Trim : SRI XP1
    I dont think it'll be too hard, probably a bit fiddly getting them on. I'm sure theres a how to, I'll have a look
  1. Knock, Knock, Knocking...
    By Carmaduk in forum Suspension, Wheels & Brakes
    Last Post: 25th May 2011, 22:20
  2. Knock Knock whos' there
    By lizard in forum Suspension, Wheels & Brakes
    Last Post: 8th November 2009, 21:18
  3. Knock Knock Knockin on heavens door
    By lizard in forum Engine & Drivetrain
    Last Post: 17th January 2009, 00:10
  4. Don,t knock the NHS
    By ed taylor in forum The 'Off Topic' room
    Last Post: 3rd March 2008, 19:49
