Results 1 to 10 of 16
Thread: EGR valve
    Regular Member G4GAV's Avatar
    Bristol
    Default EGR valve
    afternoon peoples,
    i just got home from work and only to discover that the engine light come on. put the tester on and got a code P0400 EGR valve.
    now as many of you know i had problems with this car when i done a swap for it but in the paperwork was a reciept for a bnew EGR valve in 2009.
    how long do they last for? and what is the best option for me now as in do i replace it or look at an upgrade for the engine?
    all advice greatfull
    Regular Member Dane-10's Avatar
    Feb 2012
    Sheffield
    If EGR is gone, Might be worth considering having it mapped out, In the long run will be better.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Probably just needs a clean , its worth removing the inlet manifold and boost sensor along with the egr and clean them all with carburettor cleaner , should only take about 45 minutes
    Quote Originally Posted by bobssignum View Post
    Dude, if you can take an inlet manifold off in 45 minutes you're a better man than me...
    Bristol
    How much is a good remap in the Bristol area, does any one know?
    Engine : 2.0DTi
    Mileage : 73350
    Quote Originally Posted by Penfold101 View Post
    Easy its only four bolts, one hose connection and one or two electric connection on a DTi .
    exeter
    you can on a dti engine you can have the egr boost sensor and inlet off and cleaned in 45 mins easy
    Engine : 2.0DTi
    Mileage : 73350
    great minds think alike
    Fantastic. Only one snag......
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    Facelift lights so is guess at a CDTI
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2007, 00:43
