Thread: Battery problem
    Mar 2007
    Hull
    Default Battery problem
    Daft question hoping for a quick answer I work nights and don't have time until Monday to get sorted if it's a problem. Here goes got in car this morning started engine all fine, as I pulled away I noticed a light come on dash of a battery with what appears to be a low fluid sign maybe??? Liquid halfway up the battery anybody got any ideas is it simply a water in battery top up required??? I've done a quick search but can't seem to see anything related? Thanks for any help.
    Rob
    Regular Member fingers66's Avatar
    Carpe Diem
    Sounds like coolant level warning m8.
    May 2011
    Birmingham
    im not familiar with the vectras warnings, but could be charging fault, batt level top up, I had one like that on a previous car that came on when I had high resistance from corrosion on engine earth
    West
    coolant warning light looks like this:
    http://imageshack.us/photo/my-images...002271927.jpg/
    Feb 2012
    County Armagh
    hey mate, i had the battery light come on, on my vectra c, it turned out to be a faulty alternator, the battery was only charging at 8 volts, got a new alternator battery now charging at the correct voltage, so my thought is possibly a faulty alternator hth
    Mar 2007
    Hull
    oh great! its only intermittently coming on by the looks of it.
    alternator is only a few years old aswell got replaced by vauxhall. have to take it to a garage on monday!!!
    rob
    PRESTON
    It's the low coolant warning, check the header tank is filled halfway up when cold. There is no level sensor in the battery.
    Mar 2007
    Hull
    arhhh fantastic thank you got a spare 20 mins at work ill pop out now and have a looksee.
    Thank you
  1. [Problem]Battery dies way to often
    By kristinn in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2013, 21:27
  2. Alternator or Battery Problem?
    By bu_zz2020 in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2012, 20:03
  3. battery problem
    By jpdtm in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2009, 09:51
  4. can anyone help - problem with battery and warrenty
    By A Falling Brick in forum Electrical & ICE (including SatNav)
    Last Post: 28th December 2008, 10:17
  5. Not a battery problem?
    By Craigmill in forum Electrical & ICE (including SatNav)
    Last Post: 15th August 2008, 08:58
