Thread: My gearknob keeps falling off....
    Regular Member Ben_'s Avatar
    Audiville, WM
    Default My gearknob keeps falling off....
    Anyone have the problem of gear knob popping off. It just seems to be pushed on but every so often it will just pop off with spring ... Any one know best way to fix this. Can't see that anythings missing ??????
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    One of the many common faults mate a blob of araldite up the hole did the trick for me,sounds a bit perverse that lol
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Silicon sealant fixed it for me.
    slough
    loctite bearing fit used on mine it had that anoying click when you youched the gear knob when you re fit it make sure you take out the center bit with the numbers on clean out the inside and the shaft make sure that when you put it back on all the splines line up and that the knob faces the right way so when its on and the center re fitted the center will face the correct way apply loctite beaing fit give it a gentle but frim tap on thaen fit your center cap and grin......
    Regular Member shane31's Avatar
    Sep 2011
    Staffordshire
    Haha mine used to click too thought i was the only one.. I used ptfe tape and then gave it a wack back on that was 6 months ago
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    garage receipt did mine
  1. Knob keeps falling off...
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2012, 14:34
  2. They were falling off anyway so..
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2011, 20:40
  3. It's falling off!!!
    By Keefyb007 in forum Vectra C / Signum Car Chat
    Last Post: 27th July 2010, 13:10
  4. Badges falling off!
    By david173 in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2010, 22:24
  5. my car is falling to bits
    By andy.l in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2007, 16:39
vauxhall vectra gear knob falls off
