Results 1 to 3 of 3
Thread: ENGINE LIGHT ON AGAIN (emmisions light)
    Regular Member sla002's Avatar
    hayes, middlesex
    Default ENGINE LIGHT ON AGAIN (emmisions light)
    hi guys.
    emmisions light on again. still no loss of power and all seems well.
    had the codes read last friday and reset, but light back on today (6 days later). none of the codes related to the emmisions though, only old interior module faults and 1 current cruise control fault.
    quick question, if by chance i was to rectify the problem would the light automatically turn off or does it need reseting.
    cheers.
    Feb 2011
    Selby
    Depends on the fault code. Some will clear when the ECU detects the condition has cleared, some persist until cleared manually.
    Read the codes again, and see what's there now.
    Full Member coldo's Avatar
    Scotland
    I had this issue on my vec for ages... The light emmisions light came on and stayed on for a while (several days while still driving the car about) and then go out for several days then back on etc...
    There was no loss in power, performance etc... possibly a slight reduction in ecconomey. turned out to be the O2 / Lamda sensor which was failing and flagging up an error which over time cleared. End result was a new o2 sensor.
    Opcom provided this error message...
    **********************ECU ID STARTS**********************
    Source Address: ECM
    Source Address: 0x000007E0
    Identifier: 0x0206
    System name: Z18XE
    VIN: W0L0**************
    Hardware number:2001000
    Part Number:55354416
    Software version number: 6577915104
    System description: SIEM 0100
    Type approval number: S04004
    Alpha code:
    Number of stored fault codes: 2
    P0036 - O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 2)
    (08) - Present
    P0136 - O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
    (11) - Not present
    **********************ECU ID ENDS**********************
    This is on a x18xe (z18xe) engine...
  1. misfire and emmisions light
    By paul515 in forum Engine & Drivetrain
    Last Post: 2nd August 2011, 23:17
  2. emmisions/ engine light on !!!!!
    By donniecdti in forum Engine & Drivetrain
    Last Post: 21st January 2011, 20:45
  3. emmisions light update guys
    By nph1 in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2009, 11:14
  4. Exhaust emmisions light
    By lcirillo in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2009, 13:37
  5. Emmisions light
    By dan1983 in forum Engine & Drivetrain
    Last Post: 9th October 2007, 22:21
