Results 1 to 10 of 14
Thread: cruise control problem
    Aug 2010
    Leeds
    Default cruise control problem
    Driving at about 30 mph the car seemed to coast along at same speed with my foot off the gas and looked at the instruments the green symbol was lit, touched the brakes it went off it has done it a few times at low speed any ideas?
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    knocked the button by mistake when indicating?
    Full Member spennny's Avatar
    Blantyre
    Cruise control cancels if you touch the brakes ?????
    Full Member coldo's Avatar
    Scotland
    Do you mean the light came on without you touching cruise control or do you mean you put cruise control on at 3mpg and you touched the breaks and it went off?
    If it's the first then it could be a can of worms to fix from what I understand... If it's the latter then that is spot on and how it should work as depressing the break or clutch should cause the cruise control to cancel for safty!
    Quote Originally Posted by Bigtee View Post
    That is correct, touch the clutch and/or brake and the Cruise Control is switched off
    It would be quiet scarey if you applied the brakes then the Cruise Control then started accelerating the car back to the set speed!
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 131000
    mine does the same
    Aug 2010
    Leeds
    Sorry i should have been more clear....................
    I didn't touch the stalk it just came on and should it not do it over a certain speed? ie 50 mph?
    I do use it on the motorway when cruising it works fine when i set it and just a slight touch of the brake to knock it off but at around 30 mph it came on without me doing anything.
    scottish region
    30 mph it works over
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Mine comes on below 30.
    Jul 2009
    Yorkshire
    Quote Originally Posted by MalcGSI View Post
    I've done that in error - then changed my pants!
  1. different cruise control problem
    By greenmeanie in forum Engine & Drivetrain
    Last Post: 2nd December 2015, 19:42
  2. Cruise Control Problem
    By gsi.vxr in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2010, 13:16
  3. cruise control problem
    By Lee.. in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2009, 21:37
  4. cruise control problem
    By Herman in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2008, 19:10
  5. Cruise Control problem, HELP pls
    By Ridah in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2008, 11:06
