Results 1 to 10 of 14
Thread: which lowering springs for sri?
    Mar 2012
    N. Ireland
    Trim : Sri XP
    Engine : 1.8 VVTi
    Default which lowering springs for sri?
    hi
    got a 2007 sri, after some springs for it. looking around a 40mm drop.
    what would you guys recommend?
    fyi i am looking 40mm lower than sri height, not 40mm lower than standard vectra height (the sris are a little lower standard arent they>)
    cheers
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    so you'll be looking for -55mm springs? Most of the spring makers user the standard height for their drop measurements
    To get the drop you want you'll probably have to look at coilovers
    Jun 2011
    Herts
    wow- -55 would be low!!!! you'll be catching cats eyes :-O
    Mar 2012
    N. Ireland
    Trim : Sri XP
    Engine : 1.8 VVTi
    they wouldnt be 55mm springs they would be sri specific -40mm springs, designed for the sri. most spring makers make springs their springs in a few variations for the same car.
    i.e. for a vectra they would have a line up something like this.
    petrol non-sri -40mm springs -- to lower a normal vectra 40mm
    diesel non-sri-40mm springs -- to lower a diesel 40mm. they would have a higher rate at the front cos of the extra weight of the derv engine.
    sri -40mm springs - designed for a sri to lower it 40mm from its standard height,
    diesel sri -40mm springs - again designed to lower a sri 40mm from its standard height and with a higher front spring rate to compensate for extra weight of diesel motor, cos if you put petrol -40mm springs in a diesel it would go lower than 40mm,
    Mar 2012
    N. Ireland
    Trim : Sri XP
    Engine : 1.8 VVTi
    wouldnt call 55mm low, i come here from the dub scene lol i have had cars lowered 150mm+
    have had a few cars that genuinely did catch cats eyes, lost a few splitters etc to them too
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by forde View Post
    Sorry fella the only options i've seen for most of the spring companies are engine options. I'd gladly be proved wrong though
    Mar 2012
    N. Ireland
    Trim : Sri XP
    Engine : 1.8 VVTi
    hmm yeah i was just giving an example there of what its usually like. usually you would see gti and non-gti spring options, etc.
    there doesnt seem to be that much about for the vectra c, not many coilover kits either.
    was just checking europerformance and they only seem to offer engine options.
    but i dont want to, for example, buy -40mm springs and then fit them to my sri for them to only lower it 25mm as it is 15mm lower as standard. (i read somewhere that sri is 15mm lower, can anyone confirm?)
    interested to hear what people on here have lowered their sri's on?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    The only time you get an sri option on the C is when buying standard springs
    The sri is 15mm lower than a standard non sri therefore a kit marked as a -30mm drop (from a non sri) will actually be a -15mm drop on an sri.
    IIRC you can get -45mm springs but after that you're into coilover world
    I personally used Irmscher lowering springs on mine (marked as -30mm but giving an actual drop of 15mm)
    Lovely ride and looks nice
    Jun 2011
    Herts
    still love the pic john :-)
    Dec 2011
    brechin
    put coilovers on it! my vectra c is 120mm on the front 100mm on the back and no issues with rubbing or scraping on speed bumps
  1. lowering springs
    By mvl41183 in forum Handling & Braking
    Last Post: 23rd December 2011, 23:20
  2. lowering springs
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2011, 14:56
  3. Lowering springs...
    By 19CDTi in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 23:33
  4. Lowering springs
    By parsco in forum Handling & Braking
    Last Post: 14th September 2010, 21:50
vectra c 55mm lowering springs
is it worth buying lowering springs for an sri insignia
