Thread: driver,s door closed but dash light says door is open
    Mar 2012
    scotland
    Question driver,s door closed but dash light says door is open
    hi guys i have a 03 vectra 2.2 sri my problem is with driver,s door.warning light on dash comes on to tell me door is open even when closed,ihave stripped the plug at door pillar and cleaned contacts.when i did this fault became intermittent but then returned any ideas
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Knackered door catch, if you've managed to change the problem to an intermittent one then you must have touched on the what's causing the problem
    Mar 2012
    scotland
    it defenitely electrical fault though
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    There is a switch in the door catch
    Mar 2012
    scotland
    by door catch do u mean the door stay?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    No the actual door catch that holds the door shut
    This
    http://www.ebay.co.uk/itm/VAUXHALL-V...#ht_1169wt_698
    Mar 2012
    scotland
    i mean plug at very front of drivers door not at door catch end
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Ah my apologies I thought you had stripped the door catch. Are all of the pins in the multiplug free from corrosion? It's also worth cleaning up the door catch as there have been a few threads on here about the same problem and it's turned out to be the catch at fault
    Mar 2012
    scotland
    will give the pins another clean (no corrosion) if that fails will try catch , many thanks.
  1. Driver Door showing as 'Open'
    By lew1984 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th August 2011, 12:30
  2. Replies: 9
    Last Post: 15th October 2010, 17:57
  3. Door shows as open on dash
    By colashbury in forum Vectra C / Signum Troubleshooting
    Last Post: 8th June 2010, 20:37
  4. Driver side door shut but showing open on display
    By eclipse in forum Bodywork & Interior
    Last Post: 13th August 2008, 11:14
  5. HELP door open display in dash
    By lee in forum Electrical & ICE (including SatNav)
    Last Post: 11th January 2007, 01:41
