Results 1 to 10 of 14
Thread: removing wax
    Mar 2012
    N. Ireland
    Trim : Sri XP
    Engine : 1.8 VVTi
    Default removing wax
    hey guys
    have my car waxed up with collinite but want to remove all wax etc on the car to get her clayed and then correct with the DA polisher. what would you guys usually use to remove wax/lsp? wash with fairy liquid in warm water would be my usual thinking, but all advice appreciated
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Clay will remove it mate or a chemical paint cleaner like Megs Stage 1. As part of my routine back in the day I used to foam with a strong mix of APC but the Clay stage will do it for you.
    Regular Member Chris B's Avatar
    Jan 2012
    Essex
    Claying does the removal!
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Fairy will do the job but so will claying it, take your pick!
    Jan 2012
    Essex
    If you use fairy - it will still need claying before any correction work
    Woodbridge
    Wash it with washing up liquid then clay it after. Either way you need to wash and clay before you put a machine on the paint. Washing up liquid should remove the lot. But as SHB (steve) will tell you colli is a PITA to get off your car once on it.
    How long has it been on?
    Woodbridge
    Quote Originally Posted by Chris B View Post
    Was writing my post as you posted this. As Chris said.
    Mar 2012
    N. Ireland
    Trim : Sri XP
    Engine : 1.8 VVTi
    i am aware that you need to clay before correction work. my usual practice would be, wash with fairy and warm water, then clay, then start correction work! but i never really knew how well the fairy was removing the wax. i thought it would be best to get as much as possible off before starting to clay, as then the clay would be able to get at anything under the wax layer better.
    it hasnt been on that long i waxed it a week ago... i was planning to leave it for a few months before starting correction work you see, so threw one coat of wax on for the mean time but now im just like fck it im starting now lol
    Jan 2012
    Essex
    Personally I wouldnt use a detergent as harsh as washing up liquid on my car, you may even find the residue it leaves simply replaces the wax which has to be clayed off...........
    Mar 2012
    N. Ireland
    Trim : Sri XP
    Engine : 1.8 VVTi
    does fairy leave residue? i dont think it would, its designed to easily rinse off your dishes with water, why wouldnt it on the car is my logic there lol i dont think it does any harm. i have always done it at the start of work on a car that is already waxed.
    would you guys just start claying the waxed car then?
  1. OP-COM for removing EGR
    By Paul_NI in forum Northern Ireland (RO - Vacant)
    Last Post: 17th September 2012, 19:26
  2. Removing a tow bar?
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2011, 12:08
  3. Wax Removing
    By Wolflinn in forum Detailing and Car Care Discussion
    Last Post: 10th March 2011, 09:33
  4. Tip For Removing...
    By AntB in forum Detailing and Car Care Discussion
    Last Post: 10th August 2009, 17:36
  5. Removing the egr !
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2008, 17:53
