Thread: Vectra C Clutch / master Cylinder
    Feb 2012
    lancashire
    Default Vectra C Clutch / master Cylinder
    hiya, am after some advice,i bought a 53 plate vectra 1.8 sri in january, after 2 weeks i couldnt get it into gear, took it back they told me oh its just a bit of air in the system and weve bled it up, itll be fine.
    long story sort, 2wks l8r it started again, but became ok after pumping the clutch up, then became undriveable a couple o weeks l8r, fair play to the garage the car now 6wks out of warrenty got it back in, and replaced master cylinder, brill!!
    yesterday i went to put it in reverse on my drive in the morning and low and behold grinding again!!!! i got my big syringe and pipe and back bled it, all fine again now,
    is it likely that it just wasnt bled properly when the new cylinder was fitted or is it likely to be something else???
    Regular Member Gavin2.6's Avatar
    Liverpool
    Vehicle : 1.9 cdti SRI & 2.6 Vec B & Mk1 Fiesta XR2
    Trim : 2 batteries. 2k RMS. 2x 15 SPL's
    Engine : CDTI 200 16V
    It will be the slave leaking. If the master is changed and no leaks in the pipe work then the only other place is inside the box.
    Had the slave go on a few cars now and same symptoms as you have. Eventually no amount of bleeding will stop the air getting in.
    Check the bottom of the box for fluid....
    South Central England
    9 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Slave and possibley the line too. They did not want to change that because it's about ten hours labour to to seperate the box and remove the clutch to get at the slave concentric slave cylinder.
    Liverpool
    Quote Originally Posted by nutron View Post
    Ten hours lol..... I can change flywheels in 3 in my garage with just a jack and a couple of stands. Dont know how the dealers get to these time scales.
    9 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Battery and box out, intake hose out, subframe off, wheels, drive shafts, gearbox away, change DMF, slave and clutch, put back together and refill gearbox oil. Sometimes they use blanks to stop the gearbox emptying and just top up. I was lead to believe that a clutch centring tool was required.
    Regular Member james chambers's Avatar
    Sunny Leicestershire
    Trim : SRI
    Engine : Y22SE
    Mileage : 100,000
    yeah thats a 3 hour job, with lunch in the middle! it, sounds like the slave cylinder,sorry to say!
    9 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I told a lie there, ten hours was what they quoted me for the head. It was 4.9 hours quoted for the clutch and flywheel.
  1. 2.0dti clutch master cylinder
    By Alank in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2012, 00:47
  2. master cylinder i think????
    By stickygreen in forum Suspension, Wheels & Brakes
    Last Post: 29th November 2012, 18:43
  3. Clutch + DMF + master + slave cylinder
    By Bobsta in forum Engine & Drivetrain
    Last Post: 9th November 2012, 23:33
  4. Anyone had to have a clutch master cylinder?
    By DaveW555 in forum Engine & Drivetrain
    Last Post: 13th April 2012, 22:56
  5. Master cylinder.
    By fluffsri in forum Suspension, Wheels & Brakes
    Last Post: 30th November 2009, 17:51
vectra c clutch master cylinder location
vectra c clutch master cylinder replacement
vauxhall vectra clutch master cylinder
how to remove slave cyl for clutch on vectra c 2004 petrol
05 vectra clutch master cylinder
vectra c slave cylinder
vectra c clutch hydraulics
How to fit slave cylinder 1.8 petrol 53 plate vectra
vectra clutch master cylinder replacement
how to replace clutch master cylinder signum
clutch pomp vectra c
vectra c clutch
how to change vectra c master cylinder
how to change the clutch master cylinder on a 2005 vectra
opel vectra c diesel clutch main cylinder removal
opel vectra clutch head cylinder
corsa c clutch master cylinder removal
vectra b clutch diesel master cylinder
clutch master cylinder vectra 2006
vectra c clutch slave cylinder
vectra c clutch reservoir
master clutch cylinder replacement vectra c
vectra clut
how much is a master cylinder and slave cylinder to have done on a vectra
