Thread: Climate control speed gauge
    Mar 2012
    Edinburgh
    Default Climate control speed gauge
    Hi there I have a problem with the speed control of the climate control, the problem is it only works on the 4th speed but nothing is happening when i put it on to 3,2 or 1 because of it my windows inside the car are misting up. does anyone know how to fix it? I read online that the fuses are blown but i have no idea where they are or how to change them. thank you
    Full Member Big Sig's Avatar
    Hi, have a search for the "resistor pack". Also search for "pollen filter drain" as the normal cause of them blowing is a blocked drain that fills with water and enters the car through the heater and makes the passenger side floor wet. On its way in it usually frys the resistor pack that controls the fan speed.
    11 Post(s)
    Why has your climate control only got 4 speeds?
    Mine has 7.
    Or is yours the midway climate control between standard air con and fully auto climate control?
    Mine has 7.
    Its an SRi so its unlikely to be full CC its more likely to be normal A/C.
    Although whats this midway control you mention?
    11 Post(s)
    I was referring to the 3 types of A/C
    Bog standard AC,
    Automatic AC system,
    and Electronic climate control system.
    What was the auto AC fitted to on the vec/signum range?
    11 Post(s)
    Shown in the handbook (page 153 in a 2007 0ne)
    Very similar to the bog standard AC, but
    The large centre knob has numbers (actual heat settings) stamped around the outside of it instead of just a blue to red line.
    The fan speed knob has an auto setting as well as 4 speeds.
    Never seen that fitted. Nice one
  1. climate control fan speed glitch
    By chongma in forum Bodywork & Interior
    Last Post: 6th September 2012, 15:44
  2. Climate control and GID
    By Ben_ in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2011, 19:30
  3. Auto climate control fan speed....
    By johns159 in forum Insignia car chat
    Last Post: 19th November 2010, 12:58
  4. Climate control
    By Mogsy007 in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2010, 00:19
  5. Climate Control - Yes You Can Help!!!
    By mushy2007 in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2007, 00:15
