Thread: Pick your brains
    Regular Member Danger_MouseUK's Avatar
    Jan 2010
    Merseyside
    Default Pick your brains
    On my last MOT I got the following advisories, before i spend moneys, i just wanted to run them by you lot and see what i need to buy:
    - Nearside rear upper suspention arm has slight play in pin/bush
    - Offside rear upper suspention arm has slight play in pin/bush
    - N/S steering trackrod slight play at track end.
    What should be on my shopping list then?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    N/S Steering trackrod slight play at track end.
    You need to check this out as it could be the balljoint of the lower wishbone rather than track rod end. My MOT station got this wrong and I had a track rod end replaced that wasn't needed.
    you will need 2 x rear upper suspension arms, about £35 each from eurocarparts, £75 plus each from VX. Common issue as well on all Vectras
    Jan 2010
    Merseyside
    That makes sense, how do i check the balljoint, what should i be looking for to narrow the problem down to either the rod or the wishbone?
    Jan 2010
    Merseyside
    also, can i just replace the bushing, http://www.ebay.co.uk/itm/Suspension...ht_3435wt_1165
    Or is it the whole arm?
    Jan 2010
    Merseyside
    South east
    You can just replace the bush, but it's not worth it at those prices. I'm about to do the same and have bought these:
    http://www.ebay.co.uk/itm/VAUXHALL-V...item3a62f8a670
    Jan 2010
    Merseyside
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Forgot to say my local VX dealer not only does the genuine part at £75 but a copy as well at £35. If the copy one goes faulty under warranty its much easier to get your money back from them than ebay. I would rather buy the complete arm than mess about trying to fit bushes into the old one
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by Danger_MouseUK View Post
    Jack the car up with the wheel still on.
    Get someone to move the wheel while you look underneath to see where the movement is (use an axle stand).
    When you move the wheel left to right the steering wheel should move nearly as one. Try just moving the wheel a fraction and see if the steering wheel moves.
    Try to move the wheel up and down (north to south), I dont think you should have movement
    If it does then it may well be the ball joint attached to the bottom below the hub.
    A decent garage should also be able to check this
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Jack it up get someone to grab wheel at 9 and 3 o'clock position and pull slightly
    Same again at 12&6
    You'll be able to see any movement and they should feel it
  1. Replies: 8
    Last Post: 10th November 2009, 12:22
  2. Need to pick your brains / spoiler screw problem
    By Teza in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2009, 22:52
  3. Need to pick your brains
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2008, 15:38
  4. Let me pick ur brains. engine prob :)
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2008, 16:08
  5. have you got brains
    By chrisgettings in forum General Chat
    Last Post: 16th January 2008, 23:51
