Results 1 to 10 of 28
Thread: Just bonded my swirl flaps open!
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Default Just bonded my swirl flaps open!
    Decided to bond 1,2 and 4 swirl flaps in the open position on my 93 tid(150) z19dth, as a few guys on here have done, until i can get a new inlet manifold.I previously had to re-stick my swirl bar bar back on but the gunk and fresh oil got so bad around each one i thought i havnt got much to loose by doing this, didnt notice much of a diff after, if anything it seems to pull a bit cleaner through the rev range.
    Only thing i noticed when cleaning the swirl tops they seemed to be able to spin all the way round which i didnt think is suppose to happen? But should be ok untill i can renew
    West
    Unplug the egr as well, although it will bring on the emissions light it will not cause any poor running... this will put a stop to the soot which is building up in the manifold & eventually it will clean up, i used carb cleaner through the inlet as well to aid the cleaning up process.
    I can confirm my motor pulls like a train all the way through the rev range.
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Yeh i blanked the egr the other day, thinking of disconnecting the actuator linkage and bonding number 3 swirl aswell.When you say you used carb cleaner did you spray via throttle body while holding revs? As it sounds like a good idea
    Regular Member John Bishop's Avatar
    Oct 2010
    Sounds painful, or rude. lol
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Im going to be doing this very soon as my bar is off and i cant be arrrsed keep putting it back on.I do notice the difference when i do put it on but my EGR is goosed aswell so will invest in a new 1 when i get the MOT out of the way next month.
    Have you got any pics mate?
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Quote Originally Posted by justin32 View Post
    No pics soz fella, i think theres a few somewhere on the forum just search it, it is quite fiddly to do,and when i finished blobbing it round each one it didnt look to pretty either but at least it worked, i used metal putty just make sure you clean them as good as you can first
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    My swirls (1,2,4) have been glued open for about 10k miles now. The EGR is still connected and functioning. Car does 2 x 30 mile trips per day, mainly dual carriageway. Inlet manifold is original and has done 137k miles now. Drives like new and pulls like a train
    Aug 2011
    Basingstoke
    Trim : SRI
    thanks for the tip.
    Did you notice that sometimes when cruising at lower speeds the car used to ever so slightly jerk a bit when your swirl flaps were loose? I have on mine when my bar comes off and im assuming its the flaps moving about in transit
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    thanks for the tip.
    It did. But it's like new now.
    I will change the inlet manifold when the timing belt is next done, unless it's still running like new
    Hoping to get 200k miles from the manifold though
    Aug 2011
    Basingstoke
    Trim : SRI
    Quote Originally Posted by tony-1977 View Post
    Thats wicked mate,just what i wanted to hear.
    My car is definatly lacking power and nowhere near as fast as it used to be when i first got it last september,the funny thing is though i still get excellent MPG so thats the reason why ive left it so long(about 3 months ago i noticed the bar was off)
    My EGR valve is goosed as when i push the punger in at feels like it greating and it sticks sometimes....i have taken it apart and cleaned it the propper way but its still not right.
    Did you get any smoke when pulling away before you fixed your manafold?
  1. Swirl flaps
    By Petemate in forum Engine & Drivetrain
    Last Post: 12th October 2011, 16:46
  2. Swirl Flaps & DMF
    By GenVectra in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2009, 07:56
  3. Swirl Flaps??
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2009, 16:18
  4. BMW Swirl Flaps
    By Diesel Dude in forum General Chat
    Last Post: 16th March 2008, 11:38
  5. swirl flaps
    By rob888 in forum Engine & Drivetrain
    Last Post: 6th November 2007, 21:15
swirl flaps vauxhall zafira 2.0 spray cleaner
