Results 1 to 2 of 2
Thread: Knocking brake and Snapped spring
    Regular Member Thom's Avatar
    Nov 2010
    UK
    Default Knocking brake and Snapped spring
    Problem 1) got a knocking brake after heavy braking - is this a new caliper or can i pop the piston out part way, clean it and then push it back into its pot?
    I dont believe you can buy seal kits?
    Problem 2) Another snapped spring, this time rear right - should i just buy a cheap aftermarket set or go original vaux if i dont want to fork out for shocks too?
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    [QUOTE=Thom;1761083]Problem 1) got a knocking brake after heavy braking
    i had that make sure youve got the caliper retaining pins in correctly ,if there not in correctly it will knock , i noticed mine just afer i had fitted new pads HTH
  1. Another snapped spring
    By xiodene in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2010, 17:52
  2. Snapped Spring?
    By Danialj32 in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2010, 07:11
  3. Snapped Spring
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2009, 14:51
  4. Snapped spring????
    By gibbon7000 in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2009, 12:34
  5. snapped spring
    By dannydm1 in forum Suspension, Wheels & Brakes
    Last Post: 7th November 2008, 15:16
