Thread: Fixing pulsing / flickering interior lights?
    Regular Member coldo's Avatar
    Scotland
    Default Fixing pulsing / flickering interior lights?
    Hey all,
    I have noticed since upgrading to my GID screen, double din head unit (JVC), amp and sub package I am now getting a flickering / pulsing in time with the base of any song being played. The flickering siverity is directly linked to the volume of the unit (more base and high volume makes the light flicker or pulse more.
    From research I have found that this due to the voltage draw of the amp when the music is being played and is normal... It has been sugested that a power cap may resolve this for me also...
    Now, while i Know about amps etc I know nothign about power caps... The price of them varies wildley allong with their power rating....
    Looking for help here on what to buy and wither it is even worth buying...
    Head unit is: JVC KW-AVX840
    Amp is: FLI 450S 450 Watts
    Sony Sub is: Sony Xplod 10" Sub Red (Peak 1100w)
    Other: I have connected an extra earth from the engine to the car body for extra earthing also. Install earth has been cleaned and checked also and is 100% fine. Wiring is all beefy as sould be with approp in line fues.
    Thanks in advance Guys
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    Start with the big three that will help out, you could also get a better battery a yellow top. A power cap does not help with the power surge's it just keeps the power smooth.
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    What size power cables are you using?
    Scotland
    using 4AWG cables at present...
    The big three being...
    1 - Batter Negative to Chassis
    2 - Altanator to batter positive
    3 - Engine to Chassis
    I have done the Engine to Chassis already, I can do the battery to Chassis calso quite easily... Im just not sure about doing the Altanator one... Do I get a new cable or do I just "piggyback" a second cable to the existing OEM one?
    Has anyone else done the big three on their Vectra yet? If so how did you do it?
    Scotland
    Also, does changing the batter not put more load on the altanator which can cause premature failing?
    The batter I have in the car is the OEM one issued with the car back in 2004 (to match the 1.8 Z18XE (or is it X18XE) engine. If upgrading the battery is an option then I might as well do this. What size of batter should I go for?
    Jul 2010
    This is London baby
    Trim : SXT
    Year : 2010
    Mileage : 53000
    Quote Originally Posted by coldo View Post
    You can use the same size as what there (piggyback) or take the old one out and put in a bigger one.
    Jul 2010
    This is London baby
    Trim : SXT
    Year : 2010
    Mileage : 53000
    There is alot off different opions on this matter, some say its fine and have had no problems. on the other hand some say it has killed there altanator.
  1. Lights Flickering
    By Alan/1967 in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2011, 14:20
  2. Lights Flickering
    By Chris SRi in forum Electrical & ICE (including SatNav)
    Last Post: 16th February 2011, 22:59
  3. Flickering Lights
    By jamesyoumans in forum Electrical & ICE (including SatNav)
    Last Post: 28th December 2010, 22:04
  4. Dashboard lights pulsing after a bump...
    By w33lerd33ler in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2009, 17:06
  5. lights flickering
    By mat osborn in forum Electrical & ICE (including SatNav)
    Last Post: 9th December 2008, 01:57
fix for flickering lights on vectra c
vectra interior light unit fix
