Results 1 to 10 of 11
Thread: huge current draw whilst on regenerate
    Sep 2010
    Plymouth
    Engine : 1.9 CDTi 150
    Year : 06
    Mileage : 250,000
    Default huge current draw whilst on regenerate
    I have noticed recently that whilst generating the voltage drops down as low as 9.2v!! this means i lose power steering, abs, lights go dim and the radio.
    under normal running the alternator puts out 14.2 constantly according to the info i can get via testmode on the stereo, this has been backed up with a hand held multi meter as well.
    why is there such a massive current draw? i have just had a new alternator fitted because we believed this was the issue.
    the car is an 06 Sri 1.9 150 cdti auto, it has done about 205,000 miles and this is one of tow few issues i have, however it is getting dangerous, especially when the power steering packs up.
    and suggestions gratefully received
    Regular Member simon7257's Avatar
    reading
    Have you checked that's it's not just your alternator failing under load?
    Start the car and switch everything off (lights, blowers etc) check the voltage at the battery using a multimeter, hopefully it will be about 14.5 volts then switch headlight on heaters on maximum speed and the heated rear screen on and recheck the voltage, it will drop a little but you don't want it dropping too far
    reading
    Sep 2010
    Plymouth
    Year : 06
    Mileage : 250,000
    yes we have tried the voltage drop, the alternator handles that without any issue, it holds between 14.2 and 14.4, its only when it regens does it drop.
    If the car is running and the regen is taking place the voltage varies between 12v and 13.5, if it is idling then it plummets to 9.5v and everything dies.
    All of this would not really be an issue but the car is a Taxi and so regens almost daily, some of the time when it regens it is in town and holding a fast idle with people on board is not ideal......plus the car really pumps blue smoke out of the exhaust as well!!!!
    Nothing else seems to create such a voltage drop like this does.....immediately after the regen has finished if i switch off the engine and restart it is very slow to turn over, like the battery has been drained, give it about an hour of running round and the battery appears to be back to normal.
    Both that battery and alternator have been changed on the last 6 months for various other reasons, this is a new 'issue' to add to the growing list
    Sep 2010
    Plymouth
    Year : 06
    Mileage : 250,000
    double post........
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Will it not be a good idea to get rid of the DPF and map it out?
    Engine : 1.9 CDTi
    I thought a regen just added more fuel and didnt do anything electrical?
    PRESTON
    Quote Originally Posted by tony-1977 View Post
    As this car is being used as a taxi, this is a very good idea. In the long run the cost of removing the dpf and remapping will pale into insignificance, compared to the cost of the extra fuel many regens will use. dpf equipped cars and mainly round town work really don't mix.
    I have not heard of a regen ever causing syptoms such as this. There really is no electrical involvement when regen is taking place, yes the injection timing is altered to put more fuel through the system, to get the dpf hot enough to burn off the soot, and at idle the revs can vary a little. My only thought is that maybe the dpf temp sensor is shorting out, as it only comes into play when a regen is occuring. Having said that, a regen really doesn't do it's job correctly, unless the car is run at more than 2000 rpm for the 10 to 20 mins regen normally takes. Best advice is as tony suggests, have it mapped out.
    Sep 2010
    Plymouth
    Year : 06
    Mileage : 250,000
    thanks for the comments.....the DPF and remap is something i have considered.
    Does anyone know of someone in the Plymouth/Exeter area who could do this job reliably?
    Sep 2010
    Plymouth
    Year : 06
    Mileage : 250,000
    Double post....again
  1. Draw Something
    By Big Knox in forum The 'Off Topic' room
    Last Post: 1st April 2012, 12:27
  2. How often should the DPF regenerate?
    By Blagmeister in forum Engine & Drivetrain
    Last Post: 23rd April 2009, 23:31
  3. European Cup Draw
    By mark1319 in forum The 'Off Topic' room
    Last Post: 14th March 2008, 13:44
  4. World Cup Draw...
    By BigMan in forum General Chat
    Last Post: 26th November 2007, 02:34
  5. How to draw a car in MS Paint
    By Cheeky_B in forum General Chat
    Last Post: 9th November 2006, 10:29
