Thread: How do u unplug Door switch Connector ???
    Dec 2011
    Woking
    Trim : Exclusive
    Engine : 1.8vvt (Z18XER)
    Mileage : 58000
    Default How do u unplug Door switch Connector ???
    Went to do some work inside the drivers door and stopped at the first thing - how does the wiring plug disconnect from the switch ? Can't see any tabs to press ? Do I need to poke a screwdriver in somewhere ? or two screwdirvers either side ? Thanks
    Facelift hatch 2007 1.8vvt
    Full Member spennny's Avatar
    Blantyre
    It twists off mate
    Sep 2011
    Kent
    think it pushes in the releases or pushes in and turns i might be wrong tho
    Dec 2011
    Woking
    Trim : Exclusive
    Mileage : 58000
    Found the little B - It's release tab that rotates round from near top of the cable end
    Dec 2011
    Woking
    Trim : Exclusive
    Mileage : 58000
    The tab is the bit with serations on either side but you have to press a little snib in the middle before the release tab will move.
    Mar 2012
    Edinburgh
    The attached photos show how it disconnects.
    Dec 2011
    Woking
    Trim : Exclusive
    Mileage : 58000
    Thanks for posting the photos - Took me about an hour before finding the rotating tab because it is not a different colour and there is a little lock on the tab. Anyway the photo will be useful here for future users.
  1. What method is used to disconnect door connector
    By wickedwillie in forum Electrical & ICE (including SatNav)
    Last Post: 27th November 2012, 13:18
  2. Door lock 5 pin vs 7 pin connector
    By jaap in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2012, 16:39
  3. Removing blue connector on headlight switch
    By Reading1800 in forum Bodywork & Interior
    Last Post: 5th June 2010, 11:04
  4. Oil leak at oil level switch connector
    By highmark in forum Engine & Drivetrain
    Last Post: 13th August 2009, 21:32
  5. Drivers door window switch connector
    By neilt in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2008, 21:28
unplug blue cnector vectra door
