Results 1 to 10 of 13
Thread: Illuminatiion For Ashtray
    Regular Member John Bishop's Avatar
    Oct 2010
    Default Illuminatiion For Ashtray
    Hoping someone can help.
    I am after illuminating the front ashtray seeing as tight old vauxhall did not do it. As you can see from the pic after removing the ashtray there is a connector on a grey and yellow wire. Do I use this to illuminate the ashtray and how? It has a power socket but no ciggie lighter. I am after a ciggie lighter too but so far no luck in finding a vauxhall one. Had a universal one in my missus rover a few years ago but it kept blowing the light fuse.
    P.S. I will get round to cleaning it one day
    Feb 2011
    Selby
    Pre-facelift Vectras have cig lighters and illuminated ashtrays. The cig lighter has a bulb, and there's a clear panel in the end of the ashtray to allow that light through into the ashtray itself. I'll take a photo of my 2004 Elegance's ashtray if you like.
    Should be a relatively straight swap - I'm sure I've seen someone post pictures of when they did it.
    Oct 2010
    Cheers Rich. I could not find any pics on the site. I will try to source a pre-facelift one then, hopefully it should be easier
    Full Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Well my preface have a seperat light to the ashtray, besides the illumination of the cigaret lighter.
    Jul 2010
    Warrington / Liverpool
    If you get yourself a cig lighter can I have your flappy accessory socked with that finger hole surround thing lol, looks way better!
    scottish region
    I will swap you a cig lighter brand new in the box for your accessory socket pm if intrested
    Oct 2010
    Quote Originally Posted by UncleMelon View Post
    Can do once I find ciggie lighter
    Jul 2010
    think you may have a better deal there lol ^^^
    Feb 2011
    Selby
    Quote Originally Posted by kenp View Post
    You could be right - I was going from memory in that I remembered the clear panel in the side of the removable ashtray bit.
    Oct 2010
    Had a root around under the ashtray and found another plug so went to a scrappy and found same plug with a light attached. Loking at another guys post showing his converted ashtray led I guessed it just clipped on. Found 3 of the lights which I got for nothing as they may not have worked. Was very pleased as they all worked. So that is the ashtray illuminated now. Also got a cig lighter but it did not fit, gap between the collar and the light was too shallow. Still not sure what the other connector is for though, the one with the grey/yellow wire.
    First pic shows the connector, second shows the light, third shows how they connect and the fourth shows them on the ashtray.
  1. What is under the ashtray
    By malk in forum Bodywork & Interior
    Last Post: 30th March 2009, 16:48
  2. Ashtray
    By Stephen S in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2009, 18:49
  3. What's under the Ashtray
    By squigles in forum Troubleshooting
    Last Post: 13th January 2009, 02:32
  4. Ashtray??????
    By stubopvectra in forum Styling
    Last Post: 2nd April 2008, 11:47
  5. Under ashtray
    By afterburner in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2006, 22:42
