Results 1 to 10 of 15
Thread: Timing belt
    Mar 2012
    Newcastle
    Default Timing belt
    Hi all, im new to the forum so just reading thru different posts etc. what i wat to kno is, last week i had to get my coil pack and plugs changed cost 150, i asked the mechanic about my timing belt as im currently at 59k miles, i have a vectra sri 1.8 vvt, he said not to worry about is as it dosnt need changing until about 100k miles on this engine? Is that right??
    Thanks im advance!!
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    That is right
    I'm on 88 K now, original belt.
    Have a belt kit and tools on standby, and hope to change it over Easter.
    100 K may be the correct interval, but I'll feel happier getting it done a bit early - car's 4 in June
    Dec 2011
    Seaham
    Second that, it is indeed 100k for the cambelt, it surprised me.
    Mar 2012
    Newcastle
    Il do the same then!! Will keep it goin for now but probs get it changed 65-70k? For the best u think??
    Barrow In Furness, Cumbria
    Definately. Better sooner rather than later!
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    100k or 10 years. A lot of timing belts break due to water pump failures but the VVt's water pump does not run off the timing belt apparently. Id say 80k was about the maximum, but its all down to each individual belt. If its remained dry and free from oil contamination it will most likely last a lot longer.
    Mar 2012
    Newcastle
    Not worth the risk tho is it? Il just get it done 65-70k, then i know its done!! Gonna do this air box mod tnite got a k n filter on order should be here thursday.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    i agree you dont want it to snap
    very costly else or a new engine
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    Quote Originally Posted by Denbro View Post
    you dont want this to happen
    http://www.vectra-c.com/forum/showthread.php?t=144725
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Crikey - I'm glad most of you don't work in aviation. Component changes / maintenance is planned to set points, on hours flown or time installed. You'd never pull something at 65% life
  1. anyway to do the timing belt without timing tool
    Last Post: 15th December 2012, 18:47
  2. Timing belt
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2012, 11:21
  3. Timing Belt
    By rmg1 in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2012, 06:52
  4. timing belt?
    By leonvectrac in forum Engine & Drivetrain
    Last Post: 28th April 2011, 19:02
  5. timing belt?
    By jaff in forum General Chat
    Last Post: 4th September 2008, 20:15
