Results 1 to 10 of 28
Thread: Signum 30 v6 engine problem
    Mar 2012
    alton
    Angry Signum 30 v6 engine problem
    Help please!engine hesertates when cruesing when booting the car it runs fine but can't do that in a 30 mph!!! Egr? But no black smoke scv? But no error codes
    Many thanks
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    I'd be saying a sticky egr/ throttle body.
    Can you get access to live reading see what fuel pressure is like?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Mar 2012
    alton
    Thanks for reply, only if take to dealer I guess, the other thing I have noticed it feels like the turbo is cutting in and out at low revs !
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    So many possibilities without seeing data your really stabbing round blindly in the dark.
    If you have a multimeter you could try testing MAF sensor
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Regular Member ben_3.0v6's Avatar
    Apr 2011
    EMEC #3
    The First thing I'd try as it sounds like an issue ive had recently is to change the fuel filter mine started doing similar things and was fine when being booted but idle was so lumpy. Local auto factors did me a fuel filter for around £4.
    Quote Originally Posted by jock View Post
    That sounds like the early symptoms of a blocked SCV (fuel starvation causing the turbo to switch off)
    What sort of speed and revs do you first notice the issue at?
    Mar 2012
    alton
    Hi there m8internet, it happen at 30 40 60 around 1500-1800 rpm, what sort of a job is that?
    It certainly sounds like the early symptoms of a blocked SCV
    Mine occured whilst driving at 60mph, but lower then 40mph and higher than 60mph it was fine
    As for replacing a failed SCV, the kit contains two (costing about £120, with a wait of about 2 weeks), and the labour is about 6 hours (as the fuel pump is buried within the engine)
    As above, remove and check the fuel filter, and replace
    If it is indeed this issue, it will gradually get worse over the next 2000 or so miles, and then become permanent rather than erratic
  1. Rear Signum Light problem problem - help
  2. engine problem
    By johnnyhg in forum Engine & Drivetrain
    Last Post: 2nd October 2009, 19:30
  3. problem with engine
    By stroake in forum Engine & Drivetrain
    Last Post: 13th May 2009, 18:36
  4. Replies: 3
    Last Post: 28th April 2009, 19:49
  5. 2.2 Engine problem
    By hamish178 in forum Engine & Drivetrain
    Last Post: 8th November 2007, 00:40
