Results 1 to 10 of 24
Thread: Z20NET timing chain
    Regular Member vectra100turbo's Avatar
    manchester
    Default Z20NET timing chain
    i been suffering rough idle and need to check if my chain has slipped a tooth, does anyone know the easiest way around this what seems to be a mammoth task thanks.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Is it running ruff when drivin mate
    manchester
    no mate perfect or i think it is anyway, its always had this idle problem since i got it. it idles at less than 600 but fluctuates up and down with engine judder then if i re it past 1000 its fine
    South east
    It won't be the chain that's at fault if the engine runs fine at speed. More likely to be coil pack, spark plug or water temperature sensor.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Get the cam cover off and check the timing mate. Have you done the simple things first re your idle like clean the throttle body?
    manchester
    Quote Originally Posted by Rebellion View Post
    i replaced all them mate, even egt sensor, battery, turbo, full service. its costing a fortune to find this problem and it gives no codes either to just make me scratch my head even more...
    manchester
    yeah to a fashion i cleaned it, i used intake cleaner but when i tried to do it properly it didnt like it . the butterfly plate went loose and put it in limp mode until i cleared code and drove it and it reset its position.
    we also did compression test and 2 cylinders read 9.5 and 2 read 11
    AccountKiller
    Vehicle : AccountKiller
    Trim : AccountKiller
    Engine : AccountKiller
    Year : 2000
    I have the same exact symptoms on my 2004 Vectra with Z20NET. I haven't done anything else than basic maintence inc. changing oils(engine,gearbox) and filters(air,fuel).
    I have ordered new thermostat and CTS sensor. I hope the CTS sensor fixes the stutter problem.
    Stutter seems to be more "there" when engine is cold but not in raised rpms.
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    changed your fuel filter yet?
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by Samby View Post
    Out of interest how much for the CTS?
    Sent from my R800i using Tapatalk 2
  1. Z20NET timing chain
    By vectra100turbo in forum Vectra C / Signum Troubleshooting
    Last Post: 18th March 2012, 23:12
  2. Z20NET Timing Chain Parts
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2011, 10:10
  3. Z20Net Timing chain
    By signumboy in forum Engine & Drivetrain
    Last Post: 9th September 2011, 09:43
  4. 20T Z20net Timing Chain Help
    By alanwh in forum Engine & Drivetrain
    Last Post: 21st March 2011, 10:59
z20net timing chain check
z20net erratic idle
vectra c z20net judder
