Results 1 to 10 of 14
Thread: Rear electric windows
    Nov 2011
    Oxford
    Vehicle : Sri xp1
    Engine : 1.8
    Default Rear electric windows
    As above is any wiring in the doors already or does it need putting in
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    You probably wont have the wiring in the body loom of the car, and you definitely wont have it in the back doors already.
    Have a search for rear windows on here. Plenty of threads..
    Jun 2006
    St. Helens,Merseyside
    open the rear door and locate the plug.
    unplug it from the door and check you have both of the larger pins in the plug
    if you have both then the body is wired,sadly the doors will need to have the wiring changed when the motors are added
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    It is easier if the body wiring is already in place but it isn't really a show stopper, it takes a few hours to unpick the wires you do need from an old wiring loom and it also gives you the option of adding things like heated front seat wiring too.
    The hardest part of this is that you need to remove your front seats and side covers but it isn't really that bad.
    Nov 2011
    Oxford
    Vehicle : Sri xp1
    Engine : 1.8
    The car a 57 plate Sri xp so hope loom is there will have a look and report back cheers
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    I had the wiring in my 57 plate SRi Nav XP, But i was told that may have been because I also had rear parking sensors, IDS+ etc, Hopefully you'll be lucky Chewy
    My 57 plate XP2 has them, but it's also got AFL and parking sensors...
    Nov 2011
    Oxford
    Vehicle : Sri xp1
    Engine : 1.8
    Mine hasn't got nav but has got reverse sensors
    Nov 2011
    Oxford
    Vehicle : Sri xp1
    Engine : 1.8
    Look at the wiring like mike shows but it only has one terminal not the two as shown so ideas please guys thanks
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    well that means a new loom needs fitting ...that means both front seats out ,handsbrake section out ..then all your window bits ...a full days work .
  1. Rear electric windows
    By antowens in forum Electrical & ICE (including SatNav)
    Last Post: 20th September 2013, 08:15
  2. rear electric windows
    By male 2.2 in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2012, 10:44
  3. Electric Rear Windows?
    By JDX-SRI in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2011, 00:38
  4. Rear electric windows
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2008, 19:55
  5. rear electric windows
    By Beavis in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2007, 16:12
