Thread: Rear Door locks
    Dec 2011
    Seaham
    Default Rear Door locks
    Something has just started to happen to my rear door lock, when I press the buttton to unlock, the back button bounces up and down and the door remains locked. It someimes unlocks ok, it sometimes doesnt.
    It wont open the door even if you try to manually lift the lock button?
    Before I start to strip door cards off, is this likely to be a broken wire probably around the hinge area or is the locking mechanism starting to fail??
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    I had that problem in my Siggy. Turned out that when my son was moving house we used my car for some of the delicate stuff. Someone decided just to force the door shut instead of moving whatever it was that was causing the problem. Anyway what happened was that with forcing the door shut the push rod was forced back and bent which meant that the door lock mechanism would not operate properly. Had to take the card off and realign the push rod and now all is well.
    3.2 v6 Signum and loving it
    Dec 2011
    Seaham
    Cheers will strip the door card off at the weekend.
    Just sounded like there was a clutch in the unit and it was slipping.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Did you button bounce up and down?
  1. 1 Rear door no longer opens /locks on central locking??
    By richiem in forum Electrical & ICE (including SatNav)
    Last Post: 23rd February 2012, 09:09
  2. programming the door locks
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2008, 16:34
  3. Door Locks
    By cant stand honda's in forum Electrical & ICE (including SatNav)
    Last Post: 1st September 2008, 18:41
