Thread: Engine management light as missing
    falkirk
    Default Engine management light as missing
    Just left work tonight pulled out and engine management light came on.didnt seem to pull as good and when home noticed a slight misfire on gentle acceleration and uneven idle.it is an 06 1.8 vvt.anyone got suggestions as what might be wrong before I book it in?
    Regular Member simon7257's Avatar
    reading
    I'd be tempted to say a new coil pack and spark plugs but to be sure you need to code read it, when was it last serviced? And did the definatly change the plugs?
    falkirk
    Only had it a couple months,doesn't look like the garaged changed plugs during its so called presale service!!! ,have done some checking and suspect the coil pack as well just checking if there were any other common failures causing similar problem
    Regular Member ridgers84's Avatar
    Jan 2012
    Derby
    I had exactly the same symptoms in my 1.8 vvt. Change the coil pack, whilst that is off you may as well do the spark plugs too, really easy jobs and makes the engine rev freely again.....
    Dec 2011
    Seaham
    When I got mine, they said it had been srviced, then said that was only an oil change.
    Check plugs and air filter. Do you know anyone nearby with a VVT and try their coil pack before you buy one?
    reading
    Always always always change the plugs, garages rip us of charge us and don't change them resulting in plugs which are a couple of years old at least, when spark plugs get old they build up a high resistance, the coil pack has to compensate for this which it can't do for very long, they should be changed yearly without fail, if you take a plug out you will see the porcelain at the bottom will be all golden where the plug has burnt, not good
    Dec 2011
    Seaham
    MY plugs were that old they were rusty!! Not expensive or time consuming to change, you may even find a slighteir more sprightly car?
    falkirk
    Car under warranty so will try and get coil pack replaced but will probably need to pay for new plugs will phone tommorow and find out.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
