Results 1 to 10 of 13
Thread: Anoying knocking from rear!
    Regular Member portreathbeach's Avatar
    Jan 2012
    Cornwall
    Default Anoying knocking from rear!
    I know there are loads of threads about knocking noises on people cars, but here is another one.
    When driving my 04 Signum there is sometimes a slight knocking noise from the rear driver side. I got the wife to drive the car while I jumped around in the back with my head in the boot. The noise is definitely coming from the read driver side wheel arch. (A friend said a while back that he could hear a noise from there when I drove past him slowly).
    The noise doesn't sound very loud, kind of like tapping a piece of metal on some plastic..... nothing as noisy as my front ARB bushes I need to change (squelchy crunch)
    After reading a few threads on here, I have tried a few things. Rocking the wheel....no play in it. I jacked it up, removed wheel, tried wobling various parts and checked the break pads for play....couldn't really see anything amiss.
    Anyway. When I put the car back on it's wheels, I tried lifting the rear of the car by grabbing the wheel arch. When I lift and then drop the driver side rear, there is a kind of squelchy noise, sounds a little bit like my suspected ARB bushes on the front. The passenger rear side makes no noise.
    Could this squelchy noise be the same thing that is making the knocking noise I can hear from the inside?
    Thanks for any help
    Jan 2012
    Cornwall
    Little update....
    Just went outside again with a friend so I could get him to lift and drop the car while I listened and tried to pinpoint the noise. We couldn't get the car to squelch or knock!
    Not sure if this info will help anyone point me in the right direction or not
    99% chance it's rear banana arms
    Mine where shot but even when I rocked the top
    Of the wheel there was no noise
    Stand behind your car and look at the angle of the rear wheel , if it looks like there's camber on them ( in at the top ) itll be you banana arms
    Sent from my iPhone using My thumb
    Regular Member jimbo1987's Avatar
    Jan 2012
    southwest
    rear drop link
    Regular Member lutonmatt's Avatar
    Feb 2012
    kent
    Quote Originally Posted by marktaylor View Post
    i fail them all the time when doing mots the rear top arm bushs are comman on all vectras/Signum
    Jan 2012
    Cornwall
    Just went out to check. Camber seems OK.
    I was planning on changing the banana arms and rear ARB bushes along with the front ARB bushes and drop links. These all seem very common problems on these cars.
    Also, if anyone can help, I tried to look for the size of the ARB bushes on them, but they didn't have anything on them. I used a vernier calliper around the ARB and measured 25.5 on the front and 17.75 on the rear. Does this mean I buy the 25.2mm ones for the ront and the 17mm ones for the back?
    Jan 2012
    Cornwall
    Jimbo, If I am going to the trouble of changing stuff on the rear, should I change the lot? ARB bushes, control arms and drop links. The parts don't seem that expensive and at least I know everything at the rear is good
    Jan 2012
    Cornwall
    I just drove the car again with the window open. You can clearly hear the noise, it is a kind of clattering/knocking noise. I think I'll change the whole lot, ARB bushes, arms and drop links on the rear.
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    I had a knock from the rear of my car after I had bought it, took everything out the boot and still knocking, the garage changed the drivers side banana arm and it still knocked they then put new rear shocks on and it sorted it,
    Jan 2012
    Cornwall
    I think it may be the brake pad rattling, I have read a lot of people on here with the same problem. It seems to stop when I lift the hand brake a couple of clicks, but I'm getting a friend to ride in the back later to confirm, as the hand brake warning alarm makes it hard to be 100% sure.
  1. knocking from rear
    By beat275 in forum Suspension, Wheels & Brakes
    Last Post: 24th November 2012, 12:37
  2. Knocking from the rear?
    By Steven in forum Suspension, Wheels & Brakes
    Last Post: 8th November 2012, 22:49
  3. Knocking on rear
    By richy1974 in forum Suspension, Wheels & Brakes
    Last Post: 18th October 2012, 15:59
  4. rear end knocking
    By rob10 in forum Suspension, Wheels & Brakes
    Last Post: 30th June 2012, 11:32
  5. rear knocking
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 7th October 2011, 17:28
