Thread: Loud sucking noise
    Mar 2012
    oxford
    Default Loud sucking noise
    Hi all,
    For the past week or so there has been a loud sucking noise when I go through the gears. To me it sounds like the air box is sucking to much air in but I'm not sure.
    Can anyone help on this one please
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    You running something with a turbo? Pound to a penny it's intercooler/ hose based.
    Regular Member SarahP's Avatar
    Nov 2011
    Buckinghamshire
    try your flexi pipe.. maybe blowin
    As above, update your profile with the vehicle specifications
    There are many reasons why such a noise could suddenly appear
    I would start with the air inlet, which can be found when you open the bonnet
    With the engine running, place your hand over it and confirm air is being sucked in (then turn the engine off)
    Next, go to the offside headlamp and you will find a small flexible pipe which leads to the air filter box
    Quite often this is removed to access the headlamp, so make sure both ends are in place and match up
    Then as above, start up the engine and check there is no air loss from this area
    Finally, have someone raise the revs slowly (to about 2500rpm)
    Stand directly facing the engine as they do this and trace any unusual air noises that appear
  1. LOUD grinding noise?
    By UncleMelon in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2012, 11:21
  2. mpg and loud diesel noise
    By suggs1971 in forum Engine & Drivetrain
    Last Post: 5th April 2010, 20:36
  3. loud clunking noise
    By kristian in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2010, 22:00
  4. Strange sucking noise CDTI 120
    By GoldenWonder in forum Engine & Drivetrain
    Last Post: 6th October 2008, 18:56
  5. Loud knocking noise...
    By haegwani in forum Suspension, Wheels & Brakes
    Last Post: 15th June 2007, 07:54
