Results 1 to 10 of 14
Thread: 1.9 cdti (120) starting issues.
    Regular Member 2wheelstu's Avatar
    Feb 2012
    Warwickshire
    Default 1.9 cdti (120) starting issues.
    Firstly, i should apologise for starting this thread as there are many people experiencing the same trouble. However after reading dozens of threads i am unable to find a conclusive solution.
    Basically, when i start the car (hot or cold) i have to prime the fuel pump 2-3 times, after doing this it wire fire after a couple of turns. Once it fires the car runs perfectly. If i stop the car then restart immediately it wire fire straight up.
    If i try to start the car in the way you would expect (wait for glow plug light then turn over), it turn spits and splutters and eventually fires up (sometimes little puff of white smoke). I can live with the problem but i don't want to keep nailing the starter motor for extended periods.
    I'm sure this is a fueling issue (running back to the tank) I have recently changed the fuel filter, the housing appears to be sealed up ok, can't see any diesel around those annoying push in fittings.
    I'm considering putting a non return valve in the fuel line, does anyone have any experience of exactly where to put it? The next problem with the non return is trying to get it o seal properly as the fuel lines around the housing are nylon.
    Any help or experience of this problem would be gratefully received.
    Nov 2010
    East Midlands
    Trim : design
    Hi, I'm having similar problem on my 120 and was thinking of putting a non return valve in my fuel line - had a look on fleabay and quite a few listed but all I've looked at say only suitable for low pressure fuel systems - you also need to know the internal diameter of your fuel pipe to get the right size. You need something like this http://www.ebay.co.uk/itm/Diesel-Non...6#ht_500wt_922
    but again this is for low pressure systems
    Regular Member steve19cdti's Avatar
    Nov 2010
    s.wales.bridgend
    i had the same problem sorted it out now
    starter motor didnt think it would have been that as it was turning the engine over lovely ,till one day i was haveing clicking changed the starter and battery starts first time every time downt have to wait for glow light to go out ,jump in starts first turn off key
    PRESTON
    Quote Originally Posted by steve19cdti View Post
    And the problem was??
    Nov 2010
    s.wales.bridgend
    as above mate starter moter not turning engine over faster nuff
    PRESTON
    Ahhhh, i asked while you were editing, ty anyways.
    Nov 2010
    East Midlands
    Trim : design
    Was there a noticeable difference in the speed the new motor was turning the engine over - I must admit mine does seem a bit sluggish - its had a new battery recently so that should be ok - I have considered changing the starter as well
    Nov 2010
    s.wales.bridgend
    very notisable mate i put a new battery on weeks before i change it and when i change it wow whot a diffans starts first time if u was close mate i would take mine off for u to try on urs ,onustly try starter mate ,all the money i spent on parts to solve the problem ,injectors,heater plugs,relay,filters u name it was going to put non return valve in ,a gallon petrol last resort lol
    Nov 2010
    East Midlands
    Trim : design
    Thanks for that I'll give the starter a go - any suggestions where to get one
    Nov 2010
    s.wales.bridgend
    got mean from motor facters £145 exchange or outo elctritions c i thay can repaire
  1. Replies: 0
    Last Post: 12th November 2012, 18:47
  2. starting issues
    By marc vectra sri in forum Vectra C / Signum Troubleshooting
    Last Post: 26th October 2012, 07:57
  3. Starting issues
    By jonny_adams60 in forum Engine & Drivetrain
    Last Post: 23rd February 2012, 00:02
  4. Starting issues
    By Fendy in forum Y & Z30DT Specific
    Last Post: 7th February 2012, 10:18
  5. cdti 120 bhp starting issues
    By Turbomanrony in forum Engine & Drivetrain
    Last Post: 6th December 2011, 19:45
