Results 1 to 10 of 15
Thread: Plug in boxes for 3.2 engine?
    Regular Member James C's Avatar
    Essex
    Engine : 2.8 Turbo
    Default Plug in boxes for 3.2 engine?
    I've seen the diesel boys raving about their plug in boxes and I'm wondering if anyone does anything similar for the 3.2 petrol engine. I'd like a remap, but the car's still in warranty and I don't want Vauxhall turning theri nose up at any warranty claim due to a remap. I figured if I got a plug in box I can remove it whenever the car needs to visit the stealer.
    Jul 2006
    You could always fork out for the VXR remap - wouldn't affect your warranty...
    Most of the remaps I've looked at claim to be virtually undetectable, but even so most of the companies offer a free 'return to standard' offer just in case.
    Essex
    Engine : 2.8 Turbo
    Any idea how much the VXR map is? Do I get it throught the dealer?
    Jul 2006
    Probably best to PM spoons - he seems to be on first name terms with the staff at VXR Performance Centre
    HTH
    Nope... no plug n play box for the petrols...just remaps...
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    IIRC regal autosports offer a remap for the 3.2 V6 up tp 235bhp for 350 quid thats what I'm going to get done, anyone know if that'll be an eds map?
    i beleive it is yes.. they are an agent for EDS.. but the wording is 'up to' 235BHP...
    You could PM Rugrat as i know he's running a REGAL re-map..
    Essex
    Engine : 2.8 Turbo
    Is there anything special about the petrol engines that mean tuning boxes don't work with them? I'm just curious as to why the petrol's only have the remap option whereas diesels have the tuning boxes too. I realise one's petrol and one's diesel before anyone gives that smarta**e answer
    Regular Member Ian's Avatar
    York
    Quote Originally Posted by James C View Post
    To quickly reply, desiels work by igniting the fuel when it reaches a certain compression. The fuel uses whatever air is in the cylinder to burn. A petrol uses a spark plug and the air to fuel ratio is critical to ensure that the fuel ignites at the right time, not before ie not using the spark plug.
    To this end diesels have a big air to fuel ratio as standard, ie lots more air than is required. This allows for the boxes that will chuck in more fuel by upping the pressure through the injectors, giving a better air to fuel ratio and hence more power.
    hope this helps
    Essex
    Engine : 2.8 Turbo
    Cheers for that. Surely there's a way to have a remap in a plug in box though? ie. have the car remapped, but with the map going on a chip in the plug in box that overrides the ECU signals. I'm sure I remember reading about something like that years ago.
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. Two black boxes near top of engine on v6 cdti
    By jock in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2012, 20:54
  3. Z22 YH Engine Spark plug change.
    By floppus in forum Vectra C / Signum Troubleshooting
    Last Post: 5th October 2011, 13:29
  4. engine plug cover
    By gibbon7000 in forum Engine & Drivetrain
    Last Post: 15th January 2011, 21:55
  5. Boxes and their Effects on the engine.
    By Brocks in forum Diesel Engine related
    Last Post: 19th December 2006, 17:35
