Thread: Engine light on
    Regular Member Grahamy's Avatar
    Ryton
    Default Engine light on
    Help / Advice needed.
    Done my service yesterday but noticed my engine light was still on , now the only thing i may have done wrong was to disconnect the slider connection to the airbox so i had more room to work. Would that cause the light to appear, the slider was all connected back up ,
    How can i knock this light off ??
    The car is still running as normal, no power loss or limp mode.......
    Only i can screw up a car by fitting a new air filter
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Engine? Chances are you've just given the MAF a bit of a knock. If the car runs fine it should reset itself
    Ryton
    Sorry its a 1.9 150. hopefully it will reset itself. cheers
    Regular Member Barlow's Avatar
    Jan 2012
    Chester
    Vehicle : Nissan 350Z GT
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Mine did the same after I replaced my filter on a 1.9 120.
    It cleared itself after about 50 miles or so.
    I'm guessing that the ECU learns to adapt to a crap filled filter so adjusts everything else (My airbox was like an owls nest). When you put a fresh filter in, that balance is upset - hence the light.
    Of course, I could be talking utter bollox, but that's my 2 cents.
    Jun 2011
    Herts
    its a good idea to disconnect the ecu when doing a service and leave it disconnected for at least an hour- longer if possible, that way it loses all the bad habits it learned while dealing with cruddy oil and filters. it'l then relearn its parameters much quicker when you start driving it. its best to start it and let it warm up to temp before taking it on a free flowing run for 20 miles or so after doing this.
    Ryton
    UPDATE.
    Took the car out for a run , light stayed on and i was thinking i would be having a trip to the stealers to get bum raped . Anyway later on started car to come home & the light went out . All good & PANIC OVER
    As above, you have disconnected the MAF Sensor
    As mentioned before, this is an easy and good method to test Safe Mode
    You then switch the engine off and reconnect the MAF Sensor
    The are then a few ways to disable Safe Mode now :
    remove the key and wait two hours
    or
    restart the engine three times and wait 3 minutes between each cycle (the warning light will stay on though)
    Dec 2011
    birmingham
    Hi Guys
    Please be easy as this is my first time on the forum, I have a 56reg singum 120bhp 1.9cdti, the engine managment light came on yesterday and its still on. I have not done anything recently apart from wheel balancing n new tyre two weeks ago.
    also its only giving me 24mpg. any suggetion would be a big help.
    thank you
    Jan 2012
    Chester
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Quote Originally Posted by 4447 View Post
    Hi Guys
    thank you
    When was the last time it had a full service?
    Dec 2011
    birmingham
    Quote Originally Posted by Barlow View Post
    thank you very much for getting back to me.
    It was in december when i did a full service on the car, also it has only done 36k so far
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. Engine lumpy now Engine Management Light is on
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2012, 16:51
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
