Results 1 to 10 of 24
Thread: Front LED Fogs - Couple of Questions...
    Jul 2009
    Yorkshire
    Default Front LED Fogs - Couple of Questions...
    TWO quick questions:
    1) Does the Siggy facelift use H3 or H11 front fog bulbs? (I've been told opposing answers so far!)
    2) Will LED front fogs cause CanBus warning messages (ie, like it does when fitting LED sidelights)?
    Cheers!
    Regular Member Dennisd's Avatar
    Oct 2010
    Netherlands
    Trim : Sport
    Engine : 1.9dth
    Mileage : 92000
    Just done mine with leds, not that impressed with them to be honest, and seriously thinking of changing them back to standard or xenonlook.
    1) H3
    2) Yes it will cause warning messages, and also flicker when you open and close the car.
    Oct 2010
    Netherlands
    Trim : Sport
    Engine : 1.9dth
    Mileage : 92000
    Damn Double post
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    LED bulbs are bright to look at, hence the reason they are used as DRL's and some side light bulbs. These are not designed to project light onto the road, they are designed so people see the car. They wont project light anywhere near as good the standard bulbs do so they are pretty useless if you want them to function properly as fog lights!
    Oct 2010
    Netherlands
    Trim : Sport
    Engine : 1.9dth
    Mileage : 92000
    I use my fogs as DRL's and still not impressed with them in the daylight.
    Jul 2009
    Yorkshire
    Quote Originally Posted by Dennisd View Post
    I'll probably just leave them as halogen bulbs then. I also use them as DRL's and corner lighting, and like you say, they're not that bright anyway. I might upgrade them to Osram Nightbreakers (or similar) if such a bulb exists?
    Oct 2010
    Netherlands
    Trim : Sport
    Engine : 1.9dth
    Mileage : 92000
    I see, so you also are running the HLS like me I had the Mtec H3 55w super white hid xenon, but 1 broke really quick ,within 2 months, so decided to try led. But really am dissapointed in the brightness of them in daylight.
    I now ordered these : Ring Xenon Max H3
    Hopefully they will be better as mtec.
    Oct 2010
    Netherlands
    Trim : Sport
    Engine : 1.9dth
    Mileage : 92000
    Shrug, DP
    Jul 2009
    Yorkshire
    Yep - also running HLS . I might get some Ring Xenon H3's too. I''ve also been looking at Osram Night Breakers, as I've already got them in the headlights and full beam, and they're much brighter and whiter than standard bulbs...
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    I;ve been tempted by these http://www.ebay.co.uk/itm/3006258038...ht_3557wt_1185
    but not sure now.....also thought about installing led rings into fogs to use as drl's
  1. couple of questions
    By Angel1368 in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2012, 12:47
  2. Couple Of Questions You Could Help Me With??
    By Clugie in forum Electrical & ICE (including SatNav)
    Last Post: 28th October 2009, 00:00
  3. Couple of small mods (Pics) and a couple of questions
    By bigdan in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 18:18
  4. couple of questions
    By Dave F in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2005, 20:32
