Results 1 to 3 of 3
Thread: Rear brake issues
    Regular Member *rob*'s Avatar
    Mar 2011
    Club-vaux, Moderator
    Engine : Y30DT
    Default Rear brake issues
    Recently had a few problems, got new discs and pads on the back, found a caliber nackered on the drivers side so that was replaced with a new one, then I found it sticking and smoking, caused by a bad handbrake cable, that was replaced.
    Noticed to it my handbrake is sticking on that same side again!
    Any ideas?
    Regular Member blackveccyC's Avatar
    Dumfries
    It won't be the cable that's at fault. I know when I had problems with my mot failure. Ie one side engaging and one not. It was down to the mechanism under the actual hand brake. The little plastic bit had broke. Replaced that and everything was good. Hope that helps.
    Mar 2011
    Engine : Y30DT
    Cheers I'll talk to the garage about it
  1. Issues with VXR Brake Upgrade
    By Elahi_786 in forum Handling & Braking
    Last Post: 23rd April 2012, 17:22
  2. Heated rear screen issues
    By Jonsey in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2012, 00:30
  3. Brake/Steering Issues
    By andyvectradon in forum Suspension, Wheels & Brakes
    Last Post: 13th May 2011, 13:59
  4. Rear Wiper issues
    By si_hoss in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2009, 14:30
  5. Rear Brake/Caliper issues
    By adamtaylor in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2009, 21:29
