Results 1 to 10 of 11
Thread: Limp mode help
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    Default Limp mode help
    Hi guys
    Since fitting a new inlet manifold to my f/l vec c z19dth auto the car keeps going into limp mode every few minutes having to drive with opcom connected
    After scanning it keeps coming up with these 2 same faults but doesn't give me a description.
    P2279-11
    p1901-75
    I've googled and 1 comes up as dpf fault and the other as an air intake fault, I've checked everything I can think of and there's nothing loose that I can see around the inlet manifold. With regards to the dpf I've manually regen it and saturation shows at 22%
    Can anybody shed some light or maybe know a possible cause? it's doing my head in and having to take the kids on the bus to school as car isn't safe to drive.
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    bump
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Check for intake leaks mate.
    Try squirting carb cleaner around manifold area see if revs change
    wirral
    42 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    That won't work, the air would be comming out on a diesel, never in. Use soapy water and spray around the manifold. You should see bubbles if you have a leak.
    wirral
    42 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    How does that work? It's an intake so sucking air in :s
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    It's the dpf mate
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    Quote Originally Posted by Critch View Post
    It's turbo charged, the inlet is above atmospheric pressure caused by the turbo, so if there in an intake leak it will leak boost as opposed to suck in air.
    Regular Member simon7257's Avatar
    reading
    Naturally aspirated engines (non turbo) get their air by the engines compression sucking the air so squirting carb cleaner would work but on turbo engines the turbo forces the air into the engine hence forced induction so the manifold is under pressure (that's why they have dump valves) so washing up liquid or something similar would show the leak by bubbling
    wirral
    42 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Quote Originally Posted by simon7257 View Post
    Was having a brain fart the other night. I understand it now.
  1. Limp mode?
    By chrosty in forum Engine & Drivetrain
    Last Post: 18th April 2012, 12:35
  2. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  3. Limp mode
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 18:35
  4. Limp mode
    Last Post: 3rd July 2008, 10:34
  5. limp mode
    By vauxvec in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2008, 22:03
