Results 1 to 10 of 13
Thread: 1.9 CDTI SRI Clutch
    Jun 2011
    Uk
    Default 1.9 CDTI SRI Clutch
    Hi folks
    Ok so ive had my Vectra less than a year and its costing me a fortune in repairs.
    The latest problem is the clutch has gone taking the dual mass flywheel with it aswell.
    Ive had a few quotes ranging from £700-£1400. My local mechanic can do the job for £717+vat but the cheapest place ive seen has said £700 all in(im a bit wary as it seems to cheap)
    What im wondering is can i buy the parts myself and get my mechanic to fit them? Ive found quite a few websites selling the flywheel and clutch kit but im not 100% sure what else i need.
    I know it was leaking hydralic fluid when it went so does the clutch kit sort that out?
    Basically i know i need a dual mass flywheel and a clutch kit. but what else?
    Any help of even links to products i need much appreciated
    Ryan
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Dmf, clutch kit (slave cylinder, friction plate, an other bit I can't remember). Those should be less that £500 including vat. Then you just need the 5.5 hours labour to fit it and I would recomend a fluid change rather than using the gearbox fluid again.
    Jun 2011
    Uk
    Quote Originally Posted by nutron View Post
    Thanks so what do you reckon to : http://www.carparts4less.co.uk/cp4l/...3378264&000134
    and http://www.carparts4less.co.uk/cp4l/...ea81b47&000069
    would they be the correct parts?
    Anyone know if its a 'm' gearbox or a 'f' gearbox?
    Thanks again
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    The cover plate was the other bit in the kit stupid brain wasn't working yesterday. What engine do you have?
    1.9 150ps - Z19DTH - F40
    1.9 120ps - Z19DT - pre-facelift F40
    1.9 120ps - Z19DT - facelift M32
    The flywheel there does not state what engine it is for.
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Double post removed
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Your gonna need.
    Dmf
    Clutch pressure plate and friction plate
    Csc ( slave cylinder)
    Gear box oil (will need 3 litres as f40 takes 2.4l)
    Might also be worth getting a new drain and fill plug due to they can get damaged on removal due to them getting corroded in place.
    If getting a garage to do it then you won't but if not you'll need brake fluid dot 4 aswel.
    Wish I could have found a garage to do mine that cheap.
    Mine was just shy 748 trade price. And took me 9 hours to change on my v6
    wirral
    39 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    D.p
    Jun 2011
    Uk
    thanks for all your help guys gonna order the parts and get my mechanic to fit them! Another question is im not sure the last time the cam belt was changed, would it be worth getting him to change it while hes doing the clutch?
    wirral
    39 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    If you don't know then may aswel. As its only a small cost compared to new engine/ rebuild.
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    The two can not be done together, as you would have to remove the engine mounts on bothsides and the engine would fall out lol. So he would have to do one, then the other. Two day job.
  1. 1.9 CDTi Clutch
    By Dbus in forum Engine & Drivetrain
    Last Post: 18th January 2011, 21:39
  2. 3.0 cdti clutch. Fits in 1.9 cdti?
    By Zampus in forum Engine & Drivetrain
    Last Post: 16th February 2010, 14:22
  3. new dmf + clutch 19 cdti 150
    By stevie1 in forum Engine & Drivetrain
    Last Post: 6th July 2009, 20:56
  4. CDTI Clutch
    By leeds vectra in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2006, 15:07
